305 balancer on a 350?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Timmer_71, Sep 16, 2002.
  1. Timmer_71
    Timmer_71 Registered Member
    Aug 2, 2002
    15
    Zeeland Michigan
    What would happen if i put the balancer off of a '86 305 on to my '71 350? It will fit and looks about the same size (diameter), but I just am not sure if it is safe. Anyone do this before? or is it a bad idea.
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    If it fits, you should be fine. You can't use from from a 400. But the other small-blocks are interchangeable.
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    yes it will fit on and everything, but there is a reason why the 350 one is narrower yet larger diameter, (8")
    why do you want to do that ?
  4. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,072
    484
    Grand Rapids area
    You should look at how the timing marks correspond to the keyway. My truck originally had a 305 and I think that when the 350 was dropped in, the original damper was used, although it is the larger diameter. I think the smaller is 6 1/2" and the larger is 8". In my case it may be a older/newer issue and not a 305/350 issue. Anyway, my timing mark is in the wrong place so I had to put on some timing tape in the right location.
    I think I read that either the larger or smaller one is good for high-rpm, but the other is not. I don't really know, but all small-blocks interchange the damper except the 400. The difference is internally balanced vs. externally.
  5. Timmer_71
    Aug 2, 2002
    15
    Zeeland Michigan
    Thanks guys, The reason I want to put the 305 balancer on my 350 is cause I wrecked the original pulling it off and I happen to have this one from the 305 just lying around, So being the tight-ass that I am I wanted to use this one so I don't have to spend any money.
  6. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    there are 3 different sized small block balancers, but my books show that all 69 and later smallblocks (except 400) can use the same balancers. some of the 305's used a different timing mark. as long as you make sure that the marks are the same, or remark the balancer as needed, you will be fine. I know this was years ago, but i used to get the LT-1 balancers from gm for 40.00. I don't know what current price is, but it is a bigger balancer(absorbs more vibration) GM prt#12555879
  7. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
  8. bablazer73
    Apr 4, 2000
    3,363
    upstate ny
    DAMN!!! for the little xtra money I would by a fluidampner!!
    well it has been 10 years since I bought one!! I am just getting old!!
  9. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I'd go Fluidamper, or TCI Rattler.
