305 build help needed
Discussion in 'The Garage' started by 77crewcab, Nov 15, 2006.
  1. 77crewcab
    77crewcab 1/2 ton status
    Feb 9, 2004
    1,620
    Lubbock, Texas
    First off this is for a car <Nova) to be a daily driver and cruiser not a power house but a tight budget build ($500 max).
    305 engine 700 trans 3.73 rear end
    My first thought is to just drop in the engine and trans and run it or I could put on an Edelbrock Performer and Performer cam with Q-jet and a possible rebuild/shift kit in the trans. The engine/trans is from an 86 Burb and I am just wanting something to be a reliable cruiser for daily driving that wont kill me on mileage yet wont be a total dog either.
    So what would you do? BTW I am going with the 305/700 cause I got free for the Nova with no engine/trans and I am just trying to have a decent powertrain while I work on the bodywork, suspension and interior over the next couple years.
  2. bigred81
    bigred81 1/2 ton status
    Dec 5, 2003
    323
    Falls City,TX
    For starters I would put a good set of flat top pistons and a decent cam this should help your motor out alot it would be like the early HO305 in the monte carlos.
    bigred81
  3. dyeager535
    26,980
    I'd leave it alone if it works.
    Changing stuff on a working motor can only lead to potential problems. If you want reliability, economy, and power, leave it the way the factory had it. Yes, you can improve over factory, but again, do you want to open that can of worms for a 305? I think not. :)
  4. 77crewcab
    Feb 9, 2004
    1,620
    Lubbock, Texas
    Well I plan to eventually run a 350, 383, or 400 so no I really don't want to mess with the 305. But on the other hand I don't know how long it would be before I can upgrade to another engine. I figure at least things like intake, and heads if it went that far could be transfered over to the new engine when that time comes and it would help the 305 while I have it. Keep em coming I would like to hear more opinions.
  5. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    Good dual plane intake. Small tube headers. Small 4 barrel carb. If you go to a better set of heads, you will probably lose compression. Run the HEI distributor with a curve kit, and call it good. Maybe run a little higher stall convertor to boost off the line.
  6. dyeager535
    26,980
    Then look at it this way: spend money on the 305 now, it will only take that much longer, and cost that much more to get a better engine in place.
  7. 80' 427
    80' 427 1/2 ton status Premium Member
    Nov 14, 2006
    4,089
    400
    NEBRASKA
    I have had some good running 305s in a few different vehicle but they were always the temperary motor even if that was 5 years or so. Spend money only on what you can use on your next motor. Headers, Intake, Carb will all fit the 350-383-400 you are going to build. I would limit it to those and spend the rest on the next motor. It may just suprise you how well it runs with a 3.73 gear. I would also include the use of a 95 s-10 converter to help you leave the line. It will stall about 2000 but still lock up.
  8. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,232
    490
    New Hampshire
    So the best budget power builders for a 305 would be:
    headers
    intake
    carb
    cam
    HEADERS: any brand that fits your application as a set of headers will fit any small block
    Intake: I highly recomend a Weiand Action+ or Stealth manifold
    http://store.summitracing.com/partdetail.asp?part=WND%2D8016&N=700+4294925239+4294839079+4294822065+400053+4294908216+4294840138+115&autoview=sku
    Carb: I have a Holley 4160 600 cfm, and tuned correctly, it is an excelent carb and it about the best carb for it for not a lot of $$
    http://www.jegs.com/webapp/wcs/stores/servlet/category_10001_10002_12631_-1_10271
    Cam: My favorite has always been Lunati Voodoo cams. A 268* might be just right for your set up.
    http://www.jegs.com/webapp/wcs/stores/servlet/category_10001_10002_27023_-1_10707
    Or how about a kit: http://www.jegs.com/webapp/wcs/stores/servlet/categoryitem_10001_10002_28303_-1_69631
  9. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    With those gears , and just simple external bolt ons like a new carb and intake , you can smoke the tires in a light Nova WITHOUT opening up the motor .
    I have been living with my 305 in my heavy a$$ blazer for 5 years because it runs so good , and is ultra reliable . I did open the top and change the heads at 88,000 miles , and that was 5 years ago . Mine is the 9.2:1 compression 305 . I can't light them up , but I get good mileage and enough wheeling torque to break stuff :thumb:
  10. onetonbb74
    onetonbb74 1/2 ton status
    Dec 1, 2005
    2,083
    Campbell, CA
    i would leave it alone if it runs. The most id do to it is keep it from leaking and maybe paint it and thats it. Freeze plugs for sure before you bolt it in. My roomate has a 66 chevelle hes doing the same thing to it so we put a (runner) 1968 307 in it, changed the oil pan to fit and re sealed it, put a carb from a friend on it 600 edelbrock, cheap craigslist headers, timing chain set because the single roller from 1968 had visable slack and wear and while we were at it we changed the freeze plugs and bolted it in. I thing the motor was 200 and 150 for parts and a weekend of time. Good luck.
  11. 84blazend
    84blazend Registered Member
    Jan 2, 2006
    40
    North Dakota
    I have a factory 305 in my 84 blazer, and its really not bad at all.
    My buddy bought a wrecked 85 chevy with a 305 in it. We pulled the engine and junked the rest. We put an edelbrock intake and carb on it, followed by a Speed Pro cam, then headers. We then bolted the 305 up to an sm465 and put it into a 64 C10.
    The truck hauled ass and would smoke the tires like nothing.
  12. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    that's when they actually put gears in trucks.
  13. 77crewcab
    Feb 9, 2004
    1,620
    Lubbock, Texas
    I think what I may do is install a Summit intake,headers, 2.5 duals with crossover, gasket kit, and freeze plugs and rebuilt Q-jet and see how it runs. If I want a little more power afterwards maybe I will look into getting a cam for it as well. I will probably run this motor for a few years which is why I am willing to put some money into it, but just don't want to go all out. Eventually I will probably look at a 350 or 383 but that is way down the line. Thanks for all the input.
  14. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    Mine is rebuilt (by previous owner) .030 over. I put on an Edelbrock Performer intake, ACCEL Super HEI, a rebuilt Quadrajet, and some 2 1/4" duals. Runs good, and has broke 3 ten bolt rears. I could use a higher stall convertor though.
    John
