305 egr question
Discussion in 'The Garage' started by K5-newf, Apr 28, 2007.
  1. K5-newf
    K5-newf 1/2 ton status
    Nov 5, 2005
    236
    canada
    I was given some new valve covers for my truck, but the egr wont go back on because my valve covers are slighty taller. Scine my egr is pluged can i just remove it and bolt a piece of steel plate to the egr mounting on the manifold?? or do i have to buy a special piece??
    Jason
  2. K5-newf
    Nov 5, 2005
    236
    canada
    anyone ??
  3. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    yes, you can block it off, i have before, but why don't you just got a junk yard and "pocket" a smaller one, or even "pocket" the spacer for it...
  4. K5-newf
    Nov 5, 2005
    236
    canada
    I just figured it would take 10 mins to cut one out of steel drill the bolt holes and use some silicone and then spray it with some high heat paint. I got it made now anyway. I figured scince on the summit site its just a plate then i could just make my own. junk yards are scarce around here all of them crush everything older then 10-15 years old depending on how diserble parts are.
  5. dirtynails
    dirtynails Registered Member
    Aug 28, 2005
    96
    Gosport, Indiana
    just in case this is helpful, if you don't want to make your own, the part is available at the dealership. You have the egr with the triangular base right? The part number is 14031368. I'm holding it in the package right now. I think it was about 7 bucks.
