305 or 350?
Discussion in 'The Garage' started by stockk5, Jul 28, 2005.
  1. stockk5
    Apr 13, 2004
    2,033
    71
    Cromwell, CT
    Alright well the guy that owned my truck before me told me lots of things that ended up not being true about my truck. He claims its a 305 engine in it. My friend has a 350 crate w/ 30k on it hes selling to me for really cheap. I want to make sure my engine isnt a 350 before i swap it. What ways can i definitly tell that its a 305? I dont have anything in my dash or on my doors.. those were worn off. Would the trucks vin on the dash work to decode this? If so can anyone do that for me.. its 1 G N E V 1 8 h 2 h f 1 1 0 9 1 does this mean anything to anyone w/ finding out what engine size? i hope its a 305.. cuz its sloow... its an 87 Non silverado w/ 700r, 208 bla bla
  2. hans999999
    hans999999 1/2 ton status
    Mar 9, 2005
    149
    southern connecticut
    theres a vin decoder here..click
  3. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    if you look on the back of your block, i dont remeber what side its on but, im sure some one else will post and tell ya. but, anyways you get those #'s and go to this site http://www.mortec.com/castnum.htm and match the #'s up and you'll find your answer
  4. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    engine ID
    you can look on the passenger side front portion of the block where the front of the head ends and you will find a machined flat area (just under the alternator) with numbers stamped in it. You will also find numbers on the drivers side rear of the block where the bellhousing would bolt (those are the easiest to track). Don't use the vin as someone could have changed engines.
  5. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Weeeell........ if i an not having a severe case of brain farts..... :woot: I think the 8th number on your vin is a H so according to the vin that means you have a 305.
    If you had a 350 it would be an 8. Thats according to the vin. The only way to tell for sure is to check the engine codes as said above.
  6. stockk5
    Apr 13, 2004
    2,033
    71
    Cromwell, CT
    hm well my vins say 305... and i was lookin all under the alt and i couldnt find a number code.. i dont even know how the heck to get in the back of the engine behind the heads to look for the number. I was checkin right under the alternator and basically under the heads in that area, even cleaned off my engine... hmm
  7. dyeager535
    26,977
    I'd say the flat area being talked about is more "behind" the alternator than under it. It is right where the head meets the block, if you were to stand over your engine and look straight down on it, you would see the flat pad that the numbers are stamped in. They are about the size of the characters your reading now. :)
  8. CaveBlazin
    CaveBlazin 1/2 ton status Premium Member
    May 21, 2002
    1,348
    Middle TN
    Well if the engine you have now has as much power as a moped its probably a 305 J/K Try and climb in your engine bay and hold a small hand-held mirror behind your block see if you can see some numbers if may be real greasy back there so you might have to do some cleaning. Good Luck
  9. anjieandjohn
    anjieandjohn Registered Member
    Oct 31, 2004
    61
    Virginia Beach
    Moped power?
    I still have the 305 in my truck and it is more like a Honda Spree scooter....It runs ok with the exception of the oil leak. I am looking to do swap out to a 350 as well but that will be next month sometime.
  10. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    My 305 makes respectable power. But it's .030 over, no smog, Edelbrock Performer, Accel Super HEI, and true dual's w/ no cat's help a little.
    John
  11. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    I have a 305 with the Edelbrock intake and flowmasters in my K5 and it does pretty well with the 3.73 and 35 inch tires BUT... I have no hard top, no tailgate, no bumpers and the carpet has been taken out also, that helped a lot :laugh:
