305 or 350?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by k5wantabe, Sep 4, 2001.
  1. k5wantabe
    k5wantabe Registered Member
    Sep 3, 2001
    30
    So. Cal. Lancaster
    Currently looking at buying a 73. How can I tell for sure which engine it has. Owner claims its a 350. May well be but doesn't seem to have a lot of power. Also says only 30k on rebuild. Has 33's with 3:07 gears. also no fuel inj. Could those be factors? Engine sounds and runs GREAT. What gears should it have with 33's? I figured 3:50's would return it to stock rpm. Am I close? Want to tow a 19 ft trailer(light weight).
  2. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Almost all 73's have a carbureted 350 - injection was still 14 years away. 33's with 3.07's isn't exactly a performance combo, so you can't really tell by seat of the pants.
    1 tequila 2 tequila 3 tequila Floor
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  3. k5wantabe
    Sep 3, 2001
    30
    So. Cal. Lancaster
    Thanks. I know that they didn't come out with fuel inj. (tbi) until '87. Is there any phisical way to tell the difference? I believe its the same block and such.
  4. tRustyK5
    Jul 23, 2000
    36,170
    1,375
    E-town baby!
    I'm sure if you asked nicely dyeager535 could run the numbers off the motor and tell you exactly what it originally came out of, displacement etc...
    He ran the numbers off my motor for me.
    Rene
  5. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    The only way to be certain on what it is, is to get the casting # off the rear of the block on the left side and go to mortec.com and cross the #.
    I got my number by cleaning it off with brake cleaner and jamning my head back there.
    I have heard that silly putty works for getting the # too.
    <font color=green> Too bad ignorance isn't painful </font color=green>
  6. tRustyK5
    Jul 23, 2000
    36,170
    1,375
    E-town baby!
    My number was on the front passenger side...much easier to see. It was right behind and below my alternator.
    Rene
  7. POWERMAD
    Mar 4, 2001
    3,466
    Oregon
    Now i'm curious.
    Tommorrow i'll see if it is in that location.
    I am gonna feel realy dumb if it is somewhere that is easily seen.
  8. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    The one on the back of the block is the casting number. The one on the front pad is the engine id. I will have suffix code tells engine size carb and trans engine came with. Also has plant code and number and vin #. So these are two different numbers.
  9. tRustyK5
    Jul 23, 2000
    36,170
    1,375
    E-town baby!
    Yeah, Dorian was able to tell me my 350 came froma 1 ton van with HD emissions, and it was from Cali...
    I already knew it was a 350 cuz I had the pan off, but the rest was news to me...[​IMG]
    Rene
  10. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    did they make a 305 in 73?
    Check out my 73 K5 <a target="_blank" href=http://www.geocities.com/xk5blazerx/73k5.htm>http://www.geocities.com/xk5blazerx/73k5.htm</a>
  11. tRustyK5
    Jul 23, 2000
    36,170
    1,375
    E-town baby!
    I don't think so, but the motor could have been swapped. Hell it could be a 267, or a 307...or something equally disgusting and gutless.
    Rene
  12. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
  13. dyeager535
    26,979
    Yeah, the suffix code is on the front of the block, on the small flat that is just forward of the passenger side head. Usually hidden behind the alternator somewhat, but if it is clean there, you can tell the suffix code from above or the side.
    Suffix code will tell you actual application (year, vehicle) and HP, as opposed to casting number, which can tell you GENERALLY what years it was used in, which doesn't do you much good if the casting number was used for 11 years in almost all GM vehicles, like some of them were (such as the 3970010 #)
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</a>
    No anti-theft measures on your truck? No pity when its stolen
  14. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    305s came around during the gas crunch in 1977.
    Tim
  15. i thought i read somewhere that 305s are externally ballenced like the sb 400s. if so then you could look at the harmonic balancer. it should have holes drilled in the back and kind of a weird groove on the inner lip of the balancer, like the 400s do. plus i think the ballencers on 305s are kinda small.
    <font color=blue>American Pie 2-"Have you seen my flute?" "Yeah, I stuffed it in your box."</font color=blue>
  16. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    305s are NOT externally balanced.
    Tim
  17. Sh!t, sorry. guess i was WRONG.
  18. Andreas
    Andreas 1/2 ton status
    188
    Sweden
    A 305 crank has lighter counterweights than a 350 crank, and, as you know, they both share the 3.48" stroke. Just some useless info[​IMG].
    /Andreas
    406cui of pure sh*t[​IMG]
  19. 73_BLAZER
    73_BLAZER Registered Member
    Sep 19, 2001
    6
    I had a 80 vette, in the engine number there was an H that ment it was a 305. Tom
  20. Neil
    Neil 1/2 ton status
    Jun 10, 2001
    275
    Dothan,Alabama
    the 3rd digit of your VIN is the engine code. R is 400, can't remember 350's. think it is C or L for 350.
    Neil H. Alabama.. "It's a full size thang, Jeep owners don't understand!!" '78 K5 400ci 4x4 AT,AC,PW Cheyenne., '74 C10 4x2
