305 or 350?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Brian85gmc, Sep 8, 2002.
  1. Brian85gmc
    Brian85gmc Registered Member
    Sep 4, 2002
    37
    Canton, MI USA
    How can I tell if it's a 305 or a 350 under my 85 jimmy?
    There are no labels.
  2. Dunc03
    Dunc03 1/2 ton status
    May 20, 2001
    157
    Tyler,Texas
    If you take off the distributor cap and rotor the ignition control module is underneath. It is normal a light color and is semi u shaped. If its a 350 it will have four electrical connections. If its a 305 it will have only three. I havea 86 and with a 305 and that holds true for mine. It's the only way I could tell you unless you know the casting number. The casting number is on the bottom of the block somewhere. IF you post that someone, nyself included, could tell you for certain whats in it. hopethis helps.
  3. Brian85gmc
    Sep 4, 2002
    37
    Canton, MI USA
    cool thanks.
    I just found that casting # info
  4. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I am a recovering Bronco owner.
    LOL
    I was a recovering Bronco/Ford driver when I found this site.
    I am now proud to say I have given them up completly. /forums/images/icons/grin.gif
