305 vs 350
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 1st timer, Feb 2, 2001.
  1. 1st timer
    1st timer Registered Member
    Nov 26, 2000
    27
    florida
    thinking of switching from 305 to 350 is there a big difference in power and gas milege
  2. Andreas
    Andreas 1/2 ton status
    188
    Sweden
    The 350 is better on everything while getting about the same milage. Way easier to find parts if you wanna build it a little too.
    Andreas
    406cui of pure sh*t[​IMG]
    <A target="_blank" HREF=http://hem.passagen.se/znus/>http://hem.passagen.se/znus/</A>
  3. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    if it was me i would do it you will see and feal a big differance
    s.smith 77blazer lookin 4 mud [​IMG]
  4. moneypit
    moneypit 1/2 ton status
    Sep 3, 2000
    1,382
    COLORADO
    I went from a 305 to 383 what a difference!! I should have done it long ago!! Gas mileage is pretty close to the same but the HP's are double and so is the torque!! Don't even think about it JUST DO IT! You won't regret it. Good Luck!
  5. Storm Trooper
    Nov 24, 2000
    4,640
    You will definately love a 350 or 383. The stock 87 305 only had 170 hp (lame!), my crap ranger has 145hp. If you want to stay stock, take the time to check out the hp on different years. even the stock 87 454 only had 240hp. If you are as crazy[​IMG] as me, you can get a brand new 350HO with 350hp from your friendly Chevy dealer for about $2,500 but the extras will get you $$ and you can't live where they test emissions. A good stock 350 should be easy on the wallet.
    OR JUST GO FRECKIN NUTS AND MAKE IT SCREAM!!!![​IMG]
    <font color=red>BLAZERS RULE....
    Here is my 350 just before completion.....
    [​IMG]<font color=red> Ride'in High In My K5! [​IMG]
  6. Emmettology 101
    May 9, 2000
    8,126
    FL
    Yes, I would definately do it... You will have more HP with the 350...
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; <A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A>
  7. 85k5blzr
    85k5blzr 1/2 ton status
    Jan 10, 2001
    103
    Houston, Texas
    Trust me, do it, i have an old 305 in my blazer.....let's just say i don't go anywhere fast. Get what we all would if we had the money......a Ram Jet 502....that's power.
    85 k5 blazer with an old 305....must have more power! [​IMG]
  8. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    When I swapped my 305 for a 350, not only did the power improve dramatically, I got about 7-8 mpg better! Mine's the GM 350hp model, and it's by far the best $2465.83 I've ever spent.
  9. nyyef
    nyyef 1/2 ton status
    May 16, 2000
    479
    Saudi Arabia
    you should have no doubts in your mind about this swap. to make it cheap, just throw in a stock 350, then build/modify as funds permit.
    Knife.
    knife.coloradok5.com
  10. NYC K5
    NYC K5 1/2 ton status
    Apr 3, 2000
    185
    Staten Island NY/da bronx
    i went from the 305 to 350. i got it new from gm for $1500 but i had to reuse the intake and exhaust and accesories. for the power you have to do the conversion. i lost a few mpg i could max out the 305 at about 18mpg the 350 i get a best of 15mpg but the power difference is well worth it. also when you do the swap change the clutch(manual) the water pump throw a good set of headers on and rebuild the carb. youll appreciate that later on.
