308 or 373?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Rolled, Aug 31, 2002.
  1. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    I am looking for some advice on what gears to run in my truck. Keep in mind that this truck will only be used for vacationing and towing a boat or a trailer. It will not be used off road anymore.
    Here's what I have:
    87 K5
    305 (soon to be 454 /forums/images/icons/grin.gif)
    465 hydro
    208
    35 inch tires
    stock 308 ten bolts
    I would like to get opinions on power and gas milage. I need to replace the front (bent) and am not sure if I should just track down another 308 or look for a set of 373 gears.
    If you guys could point out the pros and cons I would appreciate it.
  2. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    If you are going to be towing I would go with 3.73. They are just as common as a 3.08...
  3. captain chaos
    captain chaos 1/2 ton status
    Mar 29, 2002
    413
    dickinson, north dakota
    35's pulling boat or trailer= 3:73 or 4:10
  4. 84K5cedric
    84K5cedric 1/2 ton status
    Aug 2, 2002
    279
    Austin, TX 78660
    You should check out a tire/gear ratio chart such as this one. The 3.08's will give you better highway mileage but for towing a boat/trailer (especially with a 305 and 35's) it may not have much power.
  5. Rolled
    Jun 16, 2002
    683
    Anchorage, Alaska
    Thanks guys
    BTW Does anybody know the rpo code for 373s? 308 is GU4, not sure about the others for 87.
    Heres a realted question: Are the brakes the same on the 12 bolt and 10 bolt? I just took off the rear shoes to put new ones on and replace the wheel cylinders and was thinking that if I go with a 12 bolt and they are different then I should return the parts before I use them.
    Anybody know if the rear brake parts are interchangable?
  6. Rolled
    Jun 16, 2002
    683
    Anchorage, Alaska
    Thanks for the link Micah, thats what I was looking for /forums/images/icons/grin.gif
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    You should be able to transfer the brake parts from one axle to another. In fact, if you're lazy like me, you'll unbolt the whole backing plate and bolt it on the new axle.
  8. BLUESMAN
    BLUESMAN 1/2 ton status
    Oct 3, 2001
    951
    Phoenix(but it\'s a dry heat...like an oven!)AZ.
    I would get the 3.73's,with your future plan of installing an 454 motor,it will tow well.Look for an 12 bolt rear for that 454.I believe someone in the Az. Republic has a set of 3.73 diffs.Mike
  9. steve85fla
    steve85fla Registered Member
    Mar 27, 2001
    83
    palm beach county FL
    I would say 4:10, if you are towing they will be the best. IMO
  10. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    3.73 is GU6
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I agree that 4.10 would be better for towing.
  12. FunBlazer
    FunBlazer Registered Member
    Jul 30, 2002
    29
    Lake George, NY
    GU2=2.73
    GU4=3.08
    GU6=3.42
    GT4=3.73
    GT5 or GT8=4.10
    G80=Gov-Loc
  13. Rolled
    Jun 16, 2002
    683
    Anchorage, Alaska
    Thanks for all the responses guys.
    373's it is (or 410's) and maybe I'll get lucky and find RPO codes in the glove box while looking at parts trucks /forums/images/icons/grin.gif
