31" or 32" tires, Which?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by k5wantabe, Oct 19, 2001.
  1. k5wantabe
    k5wantabe Registered Member
    Sep 3, 2001
    30
    So. Cal. Lancaster
    31\" or 32\" tires, Which?
    I currently have 31's with 3:73 gears. I will use the jimmy mainly to tow a 19 ft travel trailer. If I go to 32's will I lose much power? Will it be noticeable? I like the looks of 32's better and more clearence for the trail, but will be towing cross crountry next summer. Any one eles tow with their k5s? What are your setups and hows it tow? Thanks guys.
    '88 Jimmy 350/700r4 3.73's 32in Maypops
  2. jbissette
    jbissette 1/2 ton status
    Aug 8, 2001
    101
    Idaho Falls, Idaho
    Re: 31\" or 32\" tires, Which?
    Going from 31's to 32' should not affect performance at all. It will drop your engine rpm less than 100 rpm's at around 60 miles per hour. You should be fine.
    88 Chevy K1500, 350 TBI, TH700R4, 3" body lift, 33x12.50x15 Tires
  3. kpanza
    kpanza 1/2 ton status
    Dec 8, 2000
    1,579
    Lake Forest, Orange County, California
    Yeah, going with the 32s shouldn't show any noticeable power loss at all. I say go with what you think looks best!
    I have towed with my Blazer (sand rail trailers, sea doo trailers, uhauls, etc). It is not the IDEAL setup for towing (because of the relatively short wheelbase), but it really isn't bad at all. I would suggest maybe getting some add a leafs or stiffer rear shocks if you plan on towing a lot, as my rear was so soft it would tend to really sag a lot when trailering, and would bottom out pretty easily.
  4. StoneyK5
    StoneyK5 1/2 ton status
    Jan 4, 2001
    472
    Birch Bay, Wa.
    My 83 has a towing package and I've gone to 32's, which the tire guys say I can run without any gear change or worry about rubbing and haven't noticed any changes at all. Have run larger tires for 10 yrs. now. It's a 350/700R.
    83K5 Silverado
    What was that bump?
  5. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Generally, its less than 1" difference. Alot of 31"s measure out at 30.9" and 32"s at 31.7". I wish I would have got 32"s instead of my 31"s but I'm building this thing to be fast and to drive everyday, so I guess I can say I have a micron more of performance, lol.
    <a target="_blank" href=http://www.geocities.com/bigkern76>http://www.geocities.com/bigkern76</a>
  6. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    Yeah go with 32's....I run 31's and I tow a 5200lb trailer easy with a sm465 3.08's setup.......I'd switch to 32's in a heartbeat...plus remember that a 10inch rim will make the tire a bit shorter also
    What? You think the hole is too deep? Lemme see...
    1985 GMC C-10 Shortbed
    1984 Chevy K-5 Blazer
  7. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Ditto, I have 32's and 3.73, and it tows well enough for me. The difference between my old 31's and 32's is basically nothing performance wise.
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    You know, 33s will probably clear!!!
    Tim
