315s 75 r16 on a 8in wide wheel or on 10 in
Discussion in 'The Garage' started by edreid, Jul 8, 2006.
  1. edreid
    edreid Registered Member
    Dec 14, 2005
    19
    so cal
    just bought this 88 blazer. currently the suspension is stock. tires on it now are 275/75 r 16 on i think 16x8 wheels. i want to get to 35x12.5 tires and a six inch lift.
    the guy at four wheel parts says i can run a 12.5in wide wheel on both the 10 in wide wheel and the 8in wide wheel. is there any difference in the two as far as fitment and backspace to get the 35s on there.
    can i stick with the wheels i have or should i look for ne ones now. i want to have a real rig for dirt not so into looks. also can i later just upgrade the wheels and buy the wide tires now anyway.
    finallly can 35 fit on the stock suspension??? so that i can just get tires now and take the truck to mexico on the sand and stuff and then get the lift kit in september? or am i dreaming.
    thanks for any advice you can give
    Ed
  2. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    1st your tires will be fine on a 10 or an 8 inch rim. 2nd You sure can fit 35's on a stock suspention if your willing to:grind::hack:
  3. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    I had a set of 315s on 8s, and looked OK. On a 10, the tire will be fatter, and I think would look better, but that's just me.
