31X12.50X15 or 31X10.50X15?
Discussion in 'The Garage' started by joshkbomb, Dec 18, 2003.
  1. joshkbomb
    joshkbomb 1/2 ton status
    Dec 18, 2003
    187
    Lafayette, CO
    I'm going to be getting new wheels and tires for my stock '87 blazer, and I have people telling me both widths. I think I'm leaning towards the 12.50's because the more in contact with the road the better. Also, I am looking at the Pro-comp A/T's(mainly a DD), any comments on these or alternatives? /forums/images/graemlins/thinking.gif
  2. clubba68
    clubba68 1/2 ton status
    Dec 6, 2002
    1,511
    Eugene-Portland, Oregon
    12.50's
    I have no experience with the ProComps.
    -Andrew /forums/images/graemlins/usaflag.gif
  3. unick
    unick 1/2 ton status
    Aug 16, 2003
    4,286
    San Diego Comufornia
    12.5 The way I see it the wider the better. I want to get 15.5's someday but that wont b till I put at least 40's on it.
    Nick
  4. scrappyk5
    scrappyk5 1/2 ton status
    Mar 17, 2002
    2,099
    virginia
    WIDER IS BETTA /forums/images/graemlins/thumb.gif
  5. Bhintz
    Bhintz 1/2 ton status
    Mar 28, 2003
    1,341
    Roswell, Ga
    why not 33s or 32s, to me they look a lot better 31s look so small
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I'll 2nd that, 33x12.50. /forums/images/graemlins/thumb.gif
  7. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Get the wider ones.
  8. joshkbomb
    Dec 18, 2003
    187
    Lafayette, CO
    Will the 32's or 33's fit without rubbing?
  9. paveslave
    paveslave Registered Member
    Oct 11, 2003
    36
    Crestview, FL
    I've found 12.50s tend to try to follow the ruts of the road and wander a bit on road. I now run 33/10.50s and the road manners seem much better, comparable to standard size tires. Also (forgot to look where you're at) if you run in snow and ice I would think the thinner tire would work better. I'm kind of biased towards BFG's myself. My 2c /forums/images/graemlins/k5.gif
  10. clubba68
    Dec 6, 2002
    1,511
    Yeah, fill out your profile so that we know where you are at. There might be some guys around ya too. /forums/images/graemlins/thumb.gif
  11. rjfguitar
    Aug 28, 2002
    9,096
    144
    california
    It's terrible with 35x16 boggers /forums/images/graemlins/rotfl.gif
  12. JIMs70K25
    JIMs70K25 1/2 ton status
    Dec 31, 2001
    524
    Chesapeake, VA
    Try 325-60R15 BFG All Terrains. 11" of tread surface look good on 10" wide rims. Saw a K5(stock) with a set not 30 minutes ago, looked good. Had them on my 70 before the lift, pics in link.
  13. GONZO2
    GONZO2 1/2 ton status
    Jul 17, 2001
    137
    formerly Great Falls, MT now Lompoc, Ca
    with stock springs i ran 32 11.5's on my 85 without any rubbing. the springs on this were sagging pretty good too.
    when the 88 was on stock springs it was able to clear 33 12.5's with only minor rubbing on the running boards when flexxing the front up. probably would not of rubbed had it not been for the runningboards.
    if you have enough gear go for the 33 12.5's they get more /forums/images/graemlins/thumb.gif
  14. Bhintz
    Mar 28, 2003
    1,341
    Roswell, Ga
    I ran 33x12.50 stock w/ no rubbing
  15. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    I would go with either a 32x11.50 BFG AT or a 33 12.50
    If you dont want to go up to a "big tire" like a 33 then get a 32 there pretty small still/forums/images/graemlins/thumb.gif
  16. joshkbomb
    Dec 18, 2003
    187
    Lafayette, CO
    That's another thing, if I went to a 33, would I have to worry about gearing or any ill effects in driving it everyday?
  17. dyeager535
    26,979
    Depends on engine, tranny, and current rear axle ratio.
    I've got/had a 350/465/3.42's/33's. No problems. Was/is no speed demon, but didn't really ever wish for more gearing. Fast enough for a truck. Highway RPM was about 2250@60MPH, which was about perfect IMO.
    Had an '83 with 305/700/3.08/31's, and it was a slug no question about it.
    PERSONALLY I think 31x12.5 would look ridiculous. All that width with no height? Look like some ricer setup.
    Depending on application (especially DD) a narrower tire is probably going to work better. Less contact patch yes, but better economy, less noise, and less chance of hydroplaning in water. Light unpacked snow, or shallow mud, the narrow tire wins. If you can't get to the bottom, get a wider tire.
    I have nothing but praise for my BFG 33x10.5R15's. Wear great, not noisey (IMO), fit stock wheels fine, no clearance issues in most stock rigs, and fairly easy to find.
    Kind of pricey, but I thought it was worth it. A mostly sotck daily driver that sees little to no off-road use would be a prime candidate for these, IF the gearing and engine could tolerate it.
    For a 350/700 truck, I'd say 3.42's are a bare minimum for 33's though. Anything less and you'll hate city driving. (besides, Overdrive would be even more worthless than it is already)
    The axle ratio code is in the glovebox on the sheet there. G80 is a Gov-lock (traction aid in the rear axle) if it's present, and any other G code will be axle ratio.
