32 spline np-205 front output
Discussion in 'OffRoad Design' started by nova, May 8, 2004.
  1. nova
    nova 1/2 ton status
    Mar 9, 2003
    285
    Laporte, IN
    i have a gm np-205 and ordered a ford 1 ton 32 spline front output shaft for it. what is all needed to install the the shaft that is on it's way. i here of all sorts of people doing this but know one says how to do this or what parts is needed. /forums/images/graemlins/ears.gif
  2. dhdescender
    dhdescender 1/2 ton status
    Aug 10, 2002
    628
    Qualicum Beach, British Columbia, Canada - Eh.
    i'm not sure what the ORD kit comes with, but here is a list of what I had to change when I swapped my ford 205 parts into my chevie...
    You need the output shaft, output bearing, bearing retainer and seal, as well as a new yoke/flange.
  3. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    You should need just the shaft, we haven't seen any difference in the ford and GM front bearing retainers so that should be the same. You will need a seal appropriately sized to match up to your yoke but that's about the only tricky part.
    unless you have a synchronized front ouput in the 205, then you need all new gears, clutchring and shift fork.......
    You'll know for sure when you get there.
