32 spline output 465
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Heavymetal, Feb 15, 2003.
  1. Heavymetal
    Heavymetal 1/2 ton status Premium Member
    Mar 30, 2001
    936
    Oregon
    I am looking at building a doubler using one of my 465's. I am getting ready to rebuild it, but was thinking about putting a 32 spline mainshaft in it while I have it apart. My question is how far out past the rear mounting suface of the tranny does the 32 spline shaft extend. I know I will have to get a 32 spline input for the 203, but I want to use my original figure 8 adapter, and want to know if the shaft will be long enough. I guess while I'm at it, I should ask how far out of the 203 past the front mounting surface does the 32 spline input extend?
  2. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    the 32 465 is the longest of the bunch
    or are you using one of Steve's new shafts
  3. Heavymetal
    Mar 30, 2001
    936
    Oregon
    No, I was just going to get a stock 32 spline shaft. What is the diff between the two, and how much are his?
  4. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    there was a thread on this somewhere, maybe in ORD section
  5. Heavymetal
    Mar 30, 2001
    936
    Oregon
    Yeah, I did a search and found that, however it does not give the actual lengths. I know a few guys on here have these cases, help a brother out and grab your tape measure. /forums/images/graemlins/grin.gif
  6. wfo163
    wfo163 1/2 ton status
    Jan 11, 2003
    100
    Charlotte, NC
    Im glad someone else asked this question. I too want to double my t-cases but I wasnt sure what 203 too use and if the 465-205 adapter can bolt to the 203. Is it the 203 from a th400 that has the 32 spline input? I currently have the 32 spline output on my 465 but its still in the truck, /forums/images/graemlins/truck.gif so sorry I cant give everyone a measurement.
  7. dyeager535
    26,980
    Believe the 465 32 spline output sticks out 10" from the case. I've got two in my garage I could measure later tonight for sure, but I believe some web site (a jeep one?) has them listed, and a yahoo or google search for SM465 will likely find it.
  8. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Here's the 3 different ones:
  9. Heavymetal
    Mar 30, 2001
    936
    Oregon
    Awesome pic. Do you know what versions the bottom two are out of?
  10. u2slow
    May 9, 2001
    2,217
    BC Canada
    Middle is the 35-spline... 2wd application.
    Bottom is the 32-spline... 81-up 4wd application.
  11. Heavymetal
    Mar 30, 2001
    936
    Oregon
    Damn, that sucks! Why the hell is it so long. I don't see any reasonable way to make that work with my current adapter. /forums/images/graemlins/frown.gif
  12. u2slow
    May 9, 2001
    2,217
    BC Canada
    You need either this one for the np205:
    Or this one for any of NP208, NP241, or the BW cases:
