32 spline SM465 to NP205
Discussion in 'The Garage' started by k30bb468, Nov 14, 2004.
  1. k30bb468
    k30bb468 1/2 ton status Premium Member
    Oct 2, 2004
    955
    NW Pennsylvania
    Anyone have a pic of the factory adapter ?
    If so could ya post it up or send it to me?
    Oh,I almost forgot I need a pic of the adapter for the round style NP205 .THANX /forums/images/graemlins/thumb.gif
  2. k30bb468
    Oct 2, 2004
    955
    NW Pennsylvania
    /forums/images/graemlins/whistling.gif Nobody has a picture /forums/images/graemlins/confused.gif
  3. dyeager535
    26,979
    I've got one out of the truck, but no picture, and can't get one for a day or so, if not longer.
    What exactly do you need a picture for?
  4. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    if it helps, the 32 spline 465/205 combo only had the round 6 bolt pattern 205, none of the figure 8.
  5. k30bb468
    Oct 2, 2004
    955
    NW Pennsylvania
    I have a 32 spl SM465 & a 32spl NP205 I need a pic so I can mabey locate the adapter to join them together & I know that they are very rare.But I found a salvage yard with a school bus full of transfer cases just need to have an idea what the HOLY GRAIL /forums/images/graemlins/bow.gif Looks like /forums/images/graemlins/thumb.gif
  6. dyeager535
    26,979
    Well, if it helps, this is from one of my old posts:
    "For archive use, I just measured the difference between the figure 8 465-205 adapter and the round 465-205 adapter.
    The figure 8 adapter is just a hair under 7", the round adapter is 10"."
    The 32 spline 465 adapter is designed for the "tall" crossmember, so it is not nearly as tall as the 10 spline 465 adapter. Not sure when the 208's started using the "tall" crossmember, but they should be the same height adapters.
    I don't see why any adapter OTHER than the 205 adapter would have a bolt hole for a shifter in the passenger side either.
    So basically, an adapter with a round pattern, 10" long, with a passenger side bolt hole for a shifter. I doubt you can go wrong with those specs.
