32s and stock lift
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Ditchdigger, Mar 16, 2001.
  1. Ditchdigger
    Ditchdigger Registered Member
    Mar 11, 2001
    96
    The Great Midwest
    Yo, dudes I'm looking at 32x11.5s and wandering if they'll fit stock lift, I'm almost positive if I had it fully flexed and turning that they would hit but I doubt I will ever have it flexed out and I do light offroading whats your guys standings on this and how much can you handle with this size when offroading also whats the Ideal gearing in the diffs and I do
    drive alot of highway and gravel? main reason is that I want too fill the wheel wells!
    If it ain't Intimidating / It ain't a Chevy!
  2. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Yeah they'll fit. I was running 32's with stock lift and never had any problems with rubbing..
    <font color=blue> Yesterday was history,tomorrow is a mystery,and today is a gift. -Taproot- </font color=blue>
  3. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    Stock lift? Isn't that contradicting? LOL!!
    [​IMG] Keep your feet dry [​IMG]
    <A target="_blank" HREF=http://muddin4fun.coloradok5.com>http://muddin4fun.coloradok5.com</A>
  4. lehtola
    lehtola 1/2 ton status
    Mar 21, 2001
    192
    North Carolina
    That's what I ran before I "lifted" mine. No problem. I've even seen some guys running 33's without a lift.
    1990 GMC Jimmy 350/TH700R4/NP241/10 bolts, 4" skyjacker lift, 35x12.50R15 BFG All Terrains on 15x10 AR Baja's, Flowmasters.
  5. MEM
    MEM Registered Member
    Feb 18, 2001
    30
    Long Island, NY
    Stock Lift. That's an oxymoron. (jumbo shrimp ...etc.)
  6. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    i have no lift and 33x12.5x16 and i dont rub the key seems to be dont get rims with a negative off set take a look at my pics i flex fairly good and still have not rubbed
    77blazer see it at<A target="_blank" HREF=http://community.webshots.com/user/ssmith6333>http://community.webshots.com/user/ssmith6333</A>[​IMG]
  7. Rocky91
    Rocky91 Registered Member
    Feb 14, 2001
    44
    Rochester, NY
    I'm in the same boat as ditchdigger. I want to add bigger tires but keep the stock height and the stock rims (if possible). I'm thinking about 33x10.5x15 tires. Would these tires rub even though they are the same width as my 31x10.5x15?
  8. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    you should be fine it might rub under extreme flex and turning while flexin
  9. crazylarry74
    crazylarry74 Registered Member
    Feb 7, 2001
    66
    Colorado
    i heard that you could fit 33's up front stock and 35's in the rear with minimal rubbing. is this true?
  10. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    not sure if you can do that but why would anyone want to?????????
  11. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    You can kiss goodbye to your 4WD system if you use mismatched tire sizes...
  12. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    Hey all
    I just put a set of 33x12.5 Wildcat EXT's mounted on the factory 15x8 rally wheels.
    Every thing fits fine and no rubbing off-road.
    see ya
    my truck's not dirty, it's earth tone paint
  13. dewey
    dewey Registered Member
    Dec 17, 2000
    59
    MA
    do you all have the "heavy duty" front end? 3 leaves up front, or regular stock suspension 2 leaves? it does make a difference...
    HEY! Your ford scratched my skidplate!!
  14. Innerpiece
    Innerpiece 1/2 ton status
    Feb 22, 2001
    145
    Mississippi (Yee Haw)
    I've got 32x11.5 on an 87 with absolutely no problems (other than diff gearing ... but that's a whole nother ball o wax) ...
    A friend in high school had 33's on an 86 and they would rub the inside of the wheel wells, but only at max turn ..
    FWIW
  15. stan2d2
    stan2d2 Registered Member
    Mar 29, 2001
    39
    NE Pennsylvania
    I had 32-11.5 BFG At on factory wheels on my Jimmy and had no problems. I went to 33-12.5 BFG At with 15 by 10 rims and have a little rubbing when the wheel is cut all the way and the suspension is under load. By the way I have 2-leaf springs up front not the heavy duty springs.
