32x11.5/15 fit with stock ride height?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by EZdoesit, Nov 29, 2001.
  1. EZdoesit
    EZdoesit Registered Member
    Oct 11, 2001
    33
    Minnesota
    I know there can be some variables which affect ride height, sagging springs etc., but I was wondering if 32x11.50's would fit my k5 without lifting it at all, I know 31x10.50's clear no problem and look kind of small, I need new tires and don't have the money to spend on 35's and a 4" lift until next year so I was thinking about 32's instead of another set of 31's for this winter. What do you guys think?
    BTW- the tires on my truck now have an actual height of 30.7" and the 32" tires I'm looking at have an actual height of 31.8"
  2. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Yep, you should be good to go. I think grim reaper ran 32's for a while.
    Surgeon General's Warning:
    Viagra and steroids may be harmful to your spouse![​IMG]
    <a target="_blank" href=http://www.nashvillek5.freeservers.com>www.nashvillek5.freeservers.com</a>
  3. According to what I've read, 31x10.50 15's are the largest that are supposed to fit stock, which is what I'm running. I think there are several people here running 33x12.50 with little to no rubbing, so I would hazard to say that the 32's should fit. Under extreme flex may be a different story, but I would think the most you would have to do is some slight fender trimming.
    American by birth, Marine by the grace of God
  4. TwoCrowsDesign
    TwoCrowsDesign 1/2 ton status
    Jul 13, 2001
    387
    I have a friend that runs them with no problem at stock height.
    John
  5. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    I ran 32s for a while with sagging springs and was fine on-road. You will need to restrict your off-road journeys some because they might rub then.
    Brian
    Check out <a target="_blank" href=http://tx85gmcguy.alloffroad.com>My Jimmy</a> with all her projects!
  6. johnny reb
    johnny reb 1/2 ton status
    Mar 6, 2000
    326
    Pittsburgh, PA
    I run 33's with no lift and I have no problems at all. Except for the 3.42 gears trying to turn them that is.
    1986 K5, New GM 350, Edelbrock Intake, K&N Air Filter, Flowtech Headers, Dual 3" Exhaust, 33" Pirelli Scorpion AT, 700R4, 3.42 gears
  7. EZdoesit
    Oct 11, 2001
    33
    Minnesota
    hey thanks, you guys are very helpful! :)
  8. BANKO
    BANKO Registered Member
    Nov 21, 2001
    18
    Sunnyvale, CA
    My brother is running 33x12.50 on his 86 K5 without any rubbing or other problems. His blazer is stock with no lift.
    I hope this helps.
    Josh
  9. RESTORE89
    RESTORE89 1/2 ton status
    Jan 31, 2001
    548
    CHAS SC
    i have 33-12.50's, and have never had them rub, and i have 200k plus miles on original
    saggy springs. i did put 411 gears in to turn them, and it made a huge difference
    32's should be no prob.
    It needs a bigger motor.
    what's in it now?
    doen't matter it NEEDS A BIGGER MOTOR
    89 350tbi/700r4h/np208/4.11's
  10. kmbonomo
    kmbonomo 1/2 ton status
    Jun 12, 2000
    115
    Traverse City Michigan
    Absolutely positively sure why not... heres some pic's of my 83 with 32x11.5's lowered to stock hight with 2 leaf front springs.. no problemo... <a target="_blank" href=http://community.webshots.com/album/19648093jHzsXjCfQV>http://community.webshots.com/album/19648093jHzsXjCfQV</a>
    Go Topless or don't go at all !!!
    <font color=red>83 K5 Full Convertible Conversion</font color=red>
