32x11.50 tires
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by FL84K5, Oct 24, 2001.
  1. FL84K5
    FL84K5 1/2 ton status
    Aug 19, 2001
    936
    Sarasota, FL
    I have an 84 Blazer with stock rims and 31x10.50 tires. I would like to put 32 inch tires on my truck, but I can't find any in 10.50 width. I do not want Swampers because 99.9% of my driving is on the street. I dont have the funds for a lift and 33's right now and I desperatly need tires. Would 11.50's fit on the stock rim? Thanks
  2. dyeager535
    26,979
    Well, if you can, you might want to check out the BFG AT 33x10.5R15 tires. They are kinda pricey (about $130) but thats not TOO much more than the 32's is it?
    No guarantee they will fit without rubbing, but at least two of us are running them on this board, with no rubbing. Thats with stock suspension, so if you flex a lot, they may. But moderate off road, with stock springs, no problems on my end.
    Only problem I can see is if the front springs are really sagged. All the tire shops locally (chain) told me that they would put them on, let me drive it, and if they rub, I could return them. To me, theres really no way to lose. The tires are most excellent on the street, and next week, looks like hunting may finally be in some snow, so I should be able to report back in two weeks on snow performance. Should be good in shallow snow, poor in mud and deep snow. We'll see.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
    Why insist on counting when the ring gear has the tooth counts stamped in?
  3. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Had 11.50's on my '81 and they worked great. Have you ever considered 33x10.50, i've heard of some people getting them to work on stock trucks. What gearing is in your diff because that can cap your choices unless you get or already have steep gears.
    <a target="_blank" href=http://www.geocities.com/bigkern76>http://www.geocities.com/bigkern76</a>
  4. Nonesuch
    Nonesuch 1/2 ton status
    Jul 16, 2001
    1,467
    Austin(Leander), TX
    my first blazer ('79) had 33x12 no names and because if the width they barely rubbed at all. it had no lift and original springs that were pretty worn out.
  5. Blazer_Boy
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    You're gonna like the 10.50 width in snow. My dad has bfg 33x12.50 M/Ts on his Jimmy, and boy do they blow in the snow. They want to glide, instead of bite. I have 31x10.50 and get better bite and have less sliding. Not saying its the miracle width because I've been stuck and spun out. Of course, being up to my skidplates in snow and hitting a drift might be my fault instead of the tires. I think a limited slip would have got me out (I'm a city-slicker so don't really want or need a locker). I did a lot of digging that night!
  6. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    32's should work. I know a guy around here that runs them on a stock Balzer with no problems and they look really good in there.
    90K5
  7. ChevyTech
    ChevyTech Registered Member
    Oct 22, 2001
    11
    Nebraska
    I am currently running Michelin 32x11.50's and have experienced no problems..
  8. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    32x11.5 will work I had them one my stock rims with no lift. 33's will fit also. If you have running boards though they might not. That is why I have 32's on my truck now. I have a set of cheesy running boards.
    My Chevy isn't broken, its just out of gas.
  9. Rebel-Rider
    Rebel-Rider 1/2 ton status
    Sep 30, 2001
    134
    North Dakota
    Re: 32x12.50 tires
    ive got 32 x 12.50
  10. Rebel-Rider
    Sep 30, 2001
    134
    North Dakota
    Re: 32x12.50 tires
    ive got 32 x 12.50
