32x12.50's fit on stock rims?
Discussion in 'The Garage' started by 1BadK-30, Mar 11, 2007.
  1. 1BadK-30
    1BadK-30 1/2 ton status
    Feb 6, 2005
    817
    Phoenix, Arizona
    I have stock width rims and would like to know if i could get away with a 12.50 on them, I dont believe this question has been asked. Any help would be nice.
  2. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    yup, they'll fit
  3. 1BadK-30
    Feb 6, 2005
    817
    Phoenix, Arizona
    Awesome thanks abunch!
  4. AFUFO
    AFUFO 1/2 ton status
    Apr 26, 2006
    329
    Chesapeake,Virginia
    They should.. what is stock, 15x8? dont go any wider than 12.50s unless your tire height goes up..that gives your sidewalls more distance which equals less angle. Make sure you wont rub when turning because of the width, what size do you have now? Flex it and turn it, see how far the tire is away from fenders.. That will give you an idea of if thell fit. Add an inch to each side of the tires tread if your coming from 10.50s
    Also, you can take a ruler and measure 8 inches inside the new tire, this will give you a basic idea of how much angle there will be on the sidewalls. Remember full air pressure will make the sidewalls bulge out even more.
    Hope this helps..
  5. 4xcrazy
    Oct 31, 2003
    9,472
    5
    Myself and also another local (Jaysbeast) had 12.5 wide tires on 15" factory 7" wide aluminum rims, on our Burbs, they were fine,,,
    and yes, they DEFINATELY fit on an 8" wide rim,,,,i personally like the look of them on the 8" wide rim over the 10" rim
    speaking of Jaysbeast, i haven't heard from him in awhile :thinking:
  6. 4xcrazy
    Oct 31, 2003
    9,472
    5
    Jaysbeast,,,,before it was all cut up and wheeled the crap out of,,,,,,
    those are the factory aluminum wheels, with 33/12.5 15" tires, i bought them a short time after when he upgraded to bigger wheels and tires :D
  7. 4xcrazy
    Oct 31, 2003
    9,472
    5
    His old tires, on my 15x8 black steelies :D stretchin out the springs alittle :D
  8. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Hers some stock 15x8's with different size tires :
    15x8 with 33x12.50'ss
    15x8 with 35x12.50
    Now , I got deja vu reading this thread :laugh:
  9. 1BadK-30
    Feb 6, 2005
    817
    Phoenix, Arizona
    Awesome guys, at a full lock turn I have 2 inches to spare on each side. This is going on my dailydriver/only truck and its a 2wd with 1ton suspension.
    and before anyone asks about the name I signed up wanting a k30, then got switched to a k5 from hanging around here, then I graduated highschool and recieved the old family truck.
    Here is some pictures. looking at these pictures I need to put the door I bought from Nate on...
  10. 1BadK-30
    Feb 6, 2005
    817
    Phoenix, Arizona
    Oh my bad I goofed up wanted to know about 11.50's, but I know they will fit because a 12.50 will.
