33-10.50R15 BFG AT/KO
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 1990SilveradoK5, May 4, 2001.
  1. 1990SilveradoK5
    1990SilveradoK5 1/2 ton status
    Jan 2, 2001
    185
    Napoleon, OH
    Got a set on order today, can not wait until I can be styling with larger shoes.
    What effect will this have on my Speedo, etc? If I do the math correctly it should knock off 4-5 MPH on it.
    Gone Large and Loving It.
    Keith
  2. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
  3. kumma
    kumma 1/2 ton status
    Oct 29, 2000
    380
    Novi, Michigan
    Please post a picture of the truck after you install the tires, i have some rims laying around that i want to put those tires on.
    thanks
    craig
  4. dyeager535
    26,975
  5. Sparky
    Sparky 1/2 ton status
    Aug 20, 2000
    423
    San Antonio(summer) Texas A and M (school year)
    Careful with the calculater, you have to realize that the faster you go the further off the speedo will read. Its not a linear function. As in, if you were to graph the speed it is off by vs. the actual speed the graph would not be a strait line. It will be off by about 5-7 at 80mph and about .2 at 5mph.
    When all else fails... Check the blinker fluid.
    78 K-5
  6. dyeager535
    26,975
    Good point. From teh calculator, you need to figure the % your speedo is off. At 10%, you will be 3.5mph off at 35, but 6 mph off at 60....you wouldn't think it matters, but had a friend just get a ticket for 4 mph over the speed limit. Tire size as well is not a constant, as 33" tires, last I checked at BFG's page (I think it was there) they said the tires were actually 32.9". I'd figure it out with a speedo check station (the freeway mileposts that are set up very accurately, not the standard ones), and a stopwatch.
    Dorian
  7. 1990SilveradoK5
    Jan 2, 2001
    185
    Napoleon, OH
    Where would I find the parts and how too's needed to adjust my speedo?
    Since it is my daily driver I want it to be close.
    Keith
  8. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    i would just take it in to a shop and have it re-calibrated then you will get the best acuracy and it dont cost that much less than a speeding ticket lol
    77blazer see it at<A target="_blank" HREF=http://community.webshots.com/user/ssmith6333>http://community.webshots.com/user/ssmith6333</A>[​IMG]
  9. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
  10. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Or - pick the speed you want to be going and knowing all you ratios and tire sizes use the calc to determine
    the RPM for that speed.... Will that work? I think that is how they keep the Nascar drivers at speed on pit lane.
    I use the dangerous method of following the fastest guy on the road.....
    And my record you ask? 2 tickets in 5 minutes in 2 states (crossing from Ca into Or). So on second thought
    ignore all my posts - HA. Dave
  11. CV202
    CV202 1/2 ton status
    Nov 14, 2000
    454
    Kingfield, ME
    Your's should use a VSS (electronic speed sensor) at the T-case, if it still has the 241C. Check out the Superlift TruSpeed. There's a quick blurb about it on page 8 of June 2001's 4Wheel Drive & Sport Utility Magazine. Looks like it sould work.
    Why do people keep calling it a Bronco!!!!! [​IMG]
  12. dyeager535
    26,975
    Is your speedo electric?? Someone brought that point up, and my dad swears he got an electric speedo out of a later Suburban (still our body style though) I didn't think ours EVER went electric, but who knows...so is it wire or cable? : )
    Dorian
  13. 1990SilveradoK5
    Jan 2, 2001
    185
    Napoleon, OH
    I believe it is electric, but I will look at it tonight and let you all know.
    Keith
  14. dyeager535
    26,975
    Should be easy to tell right at the transfer case. I believe even then it would be gear driven, and as long as there was a wide variety of gears, you should be able to just change them.
    Dorian
  15. 1990SilveradoK5
    Jan 2, 2001
    185
    Napoleon, OH
    OK, I agree that it is easy if you know how to do it. And yes it is an electronic gauge.
    dyeager535 could you provide a short step by step that would get me through it? I have done almost all of my own work since owning a garage, however this is my first 4X4 working with transfer cases and such.
    Also how do I know what gear to replace the stock one with?
    Keith
  16. 1990SilveradoK5
    Jan 2, 2001
    185
    Napoleon, OH
    Can't hardly wait, received the call this morning and my tires are in. I will be getting them installed tomorrow morning, if I can get ahold of a digital camera I will get before and after picures of my truck and put them up on my site.
    Can't wait, Tires tomorrow and shocks this weekend. Should ride like a different truck by Monday.
    Keith<P ID="edit"><FONT SIZE=-1>Edited by 1990SilveradoK5 on 05/08/01 09:49 AM (server time).</FONT></P>
  17. dyeager535
    26,975
    I really can't guarantee that my method will work. I've changed numerous speedo gears, but all on 2WD (no t-case) mid 80's (no electric speedo) GM cars. All you have to do though, if the gears aren't too far off (yours shouldn't be) is find where the speedo wire goes on the t-case. Usually one bolt clamping the speedo sleeve to the t-case, kinda like the distributor hold down. Unbolt that, and twist/pull (don't pry if the piece is plastic, they WILL break) the assembly out. There should be some type of driven gear (drive gear should be on the t-case output shaft, "under" the speedo driven gear. Once you get it out, that gear probably just pulls out or something, and its just a matter of getting one with the right tooth count to compensate...all GM speedo gears I have seen so far have the tooth count stamped on them somewhere (usually small) so there is no reason to count teeth.
    Glad you got the tires...lets see some pics! :)
    Dorian
  18. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Just drive the same speed what the people around you are doin....My speedo has been off for about 4 years now.
    <A target="_blank" HREF=http://community.webshots.com/user/vwryda>http://community.webshots.com/user/vwryda</A>
  19. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    Correction Eric, just drive about 10 MPH slower than every body else and you'll be doing the speed limit LOL!
    [​IMG]<font color=blue> I'd rather have a bottle in front of me, than a frontal lobotomy!
  20. 1990SilveradoK5
    Jan 2, 2001
    185
    Napoleon, OH
    No digital camera at this point and my confuser at home is not compatable with my scanner so It may be a week before I get pictures up.
    <A target="_blank" HREF=http://1990silveradok5.coloradok5.com/>http://1990silveradok5.coloradok5.com/</A>
    Keith
