33" tires on factory wheels
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by archer, Oct 29, 2000.
  1. archer
    archer 1/2 ton status
    Aug 17, 2000
    136
    tn
    33\" tires on factory wheels
    I have 31.10/50's on my factory wheels right now and was wondering if I have to buy new wheels to fit 33's. After new paint, lugnuts and caps, I think these will look OK, and I really want to save the 600.00. is there a particular width tire I need to consider? I'm not positive, but I think these are 15x8 wheels. thanks for any follow-up posts!
    "who dares wins"
  2. Bigmeats
    Bigmeats 1/2 ton status
    Jul 29, 2000
    523
    Manhattan IL
    Re: 33\" tires on factory wheels
    I just sold a set of 33's on stock wheels and they did look good. They were 33-12.5's they "pooched" out from the rims a littl, But I dont mind that look. I think you cant go wrong with saving some cash. You can always buy different set of rims later. Just my $.02
    Bigmeats
    Carl...75 Blazer...Manhattan IL
  3. Toad
    Toad 1/2 ton status
    Mar 15, 2000
    157
    Utah
    If the rims are 15 X 8 you can run 33 x 12.5 x 15 just fine. If you don't have a lift I probably wouldn't do that though. Upon full compresion you are likely to have a tire rub and possibly cut the tread. I know I did it. Each vehicle is different though.
    If you are not going to lift it and just want bigger tires, go to 32 X 11.5 X 15. They should fit without rubbing and are close enough that the power loss will be minimal and the speedometer won't be too far off.
  4. archer
    Aug 17, 2000
    136
    tn
    I'm planning on lifting it 4". I think I'm going to go with a Rough Country system (springs all around, shocks, steering arm etc...) I'm just going to do it all at once. I have whimpy little 3.08 gears and a 305, I'm already looking at new tires (these new Generals are NICE by the way) and new gears to replace these and I don't want to add 800.00 to the mix for new wheels. I don't care if they puff out on the sides a little, so long as they don't pop off at 60mph. I mean, the grand total is already over 1,500.00 without wheels. That's alot of bones.
    "who dares wins"
  5. 72Blazerod
    72Blazerod 1/2 ton status
    May 18, 2000
    264
    Vancouver, British Columbia, Canada
    I am running 33 x 12.5's on my stock 15x8 Ralley Wheels right now and I haven't had any problems at all.
    72Blazerod
  6. archer
    Aug 17, 2000
    136
    tn
    That's exactly what I wanted to hear, Thanks alot, folks.
    "who dares wins"
  7. backlash
    backlash 1/2 ton status
    Oct 21, 2000
    519
    Northern, VA.
    Hey 72blazerod,
    Do you happen to have a pic of how that looks. Just curious.
  8. blazen91
    blazen91 1/2 ton status
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    I almost bought a Blazer with 33's on stock alum. wheels and it looked good.
    blazen91
  9. jcg
    jcg 1/2 ton status
    Mar 19, 2000
    660
    Rochester, NY
  10. walt88
    walt88 1/2 ton status
    May 24, 2000
    430
    Monmouth County, NJ
    I had 33x12.5 on my stock blazer before I lifted it. If I hit a bump just right or too fast, it tore up my body. There are still marks where it rubbed and tore metal and stuff. I wouldn't do it.
    Keep the shiny side up, and the greasy side down.
  11. bigjbear
    Feb 18, 2000
    13,970
    450
    Marietta GA
    I have BFG 35x12.50-15 M/Ts on my stock rims. I wouldn't go any wider. The narrow rim helps keep the bead seated when aired down. I also like the steel rims ability to take a beating.
    Jim '80 GMC
    Vote Freedom First!
    http://www.bigjbear.coloradok5.com
