33" tires on stock springs
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jacobean, Mar 10, 2003.
  1. jacobean
    jacobean Registered Member
    Sep 18, 2002
    18
    33\" tires on stock springs
    I want to buy a set of 33-12.5-15 mud tires and hope to put them on my 74 Blazer with stock springs. will this work with minor or no trimming?? /forums/images/graemlins/confused.gif
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Re: 33\" tires on stock springs
    dependent upon your definition of minor yes...
  3. rugger03
    rugger03 1/2 ton status
    May 14, 2000
    829
    around
    Jaco- they can fit depending on the true hight and width of the tire, and how bad your stock springs are riding. Also depends how you drive it. You will here both sides from different people, there is a ton of information here on this subject. You might be surprised at what you might find using the search feature. good luck,
    rugger
  4. jacobean
    Sep 18, 2002
    18
    How much cutting did you need to do to your rig???
  5. emoo99
    emoo99 1/2 ton status
    Jan 16, 2003
    494
    Washington
    i just put some pro comp 33x12.50 15's on 8inch rim and they fit but when i turned i was about .5 inches away from hitting the finder so i proped my wheel on a curb and turned the wheel, the shock makes the wheel go in the fender at a curve, not straight up so i cut about and inch off the inside corners(can't even tell) and now i'm all good with stock springs..
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    The shock is not what makes the axle move backwards and forwards under compression. That's how leaf springs work. Depending on the arch, they either get longer or shorter as they compress and the opposite when they extend. Just the nature of the beast.
  7. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Read this.
    It should give ya everything you need to know for this.
  8. Big'nBadK5
    Big'nBadK5 Registered Member
    Feb 9, 2003
    84
    Pjs, Ny
    I have an '85 with stock sprigs right now and it has 33x12.5r15's on it no problem. on or off road. But it is truly different for everyone. the outer lugs on a mud tire might pose a problem but you might just have to beat the lip back abd you'll be fine. just try it, it's the onyl real way to find out. good luck. /forums/images/graemlins/thumb.gif
  9. Panther212
    Panther212 Registered Member
    Jan 4, 2003
    56
    Phoenix, AZ
    My 33's fit no problem... I've never had em rub /forums/images/graemlins/pimp1.gif
  10. Catman
    Catman Registered Member
    Feb 4, 2003
    53
    Yucca Valley, Calif.
    My 90K5 w/33"x12.50"x15's would rub on the rear lip of the front fender well. Minor cutting or a 4" lift would make it work /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif
