33" Tires
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by chev4life, Dec 3, 2001.
  1. chev4life
    chev4life 1/2 ton status
    Jun 21, 2001
    416
    San Jose, CA
    33\" Tires
    Anyone know if its possible to fit 33" tires on a stock height '87 K5? If not what is the min lift to do to fit them and whats a good lift to do for all around....towing, snow, mud, just alot of screwing around?
  2. White Knight
    White Knight 1/2 ton status
    889
    Ft Worth,Texas
    Re: 33\" Tires
    They wouldn't fit on my '83, went to a 4 " pro-comp, and cut a little bit of fenders, it rubbed under full flex.
    White Knight
  3. greg83k5
    greg83k5 1/2 ton status
    Nov 2, 2001
    230
    space sity houston, texas
    Re: 33\" Tires
    they fit my '83........ rubbed just a bit on the front driver's side, back lip by the door. bashed it back with a hammer and was good to go. this was on-pavement, surely getting all flexed up would result in rubbin'....
  4. Slayer
    Slayer 1/2 ton status
    Oct 17, 2001
    225
    Eastern Colorado, jokingly referred to as Western
    Re: 33\" Tires
    33's wouldn't fit my stock '77, but they fit perfectly with the 4inch lift. Sometimes I wish that I had cut the fenders and gone with 35's, oh well. I had some bad luck with Goodyear Wrangler AT's, and bought BFG AT KO's and thought that they were good until winter came, now I don't know what will work good on snow and ice. Gotta do some more research on tires and weather performance. Good luck with your tires.
    <font color=blue>I don't know everything, I just think that I do.............</font color=blue>[​IMG]
  5. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Re: 33\" Tires
    I could only fit 32's at stock on my 84. I lifted it 2.5 inches and they fit fine...Only have rubbed a couple of times.
    <a target="_blank" href=http://www.community.webshots.com/user/vwryda>Welcome to Bucketheadland</a>
  6. 83bowtyblazer
    83bowtyblazer 1/2 ton status
    Jul 29, 2001
    132
    Ft. Dix, NJ
    Re: 33\" Tires
    I Got 33's on my 83 with factory suspension and the only time it rubs is full right turn while mashing the gas in reverse. I've run up over curbs and stuff to see if they's rub and they didn't.
    Ryan
    Never knock on DEATH's door. Ring the bell and run...he hates that!!!!
  7. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    Re: 33\" Tires
    it depends on your rims if you have a negative offset they wont fit without rubbing but if you have a positive offset like i do they fit fine i can score a 704 on a 23 degree rti ramp and dont rub i have jumped my blazer and still no rubbing i wheel fairly hard and have never rubbed take a look at my pics and videos below
    wheeling videoshttp://community.webshots.com/user/ssmith6333
  8. SWIVEL
    SWIVEL Registered Member
    Jul 26, 2001
    18
    NEW JERSY(ARM-PIT OF THE WORLD)
    Re: 33\" Tires
    just this past weekend i slapped 33x12.50x15 TSLs on my stocker. I had to do a two second trim job that is not even visible to the daily driver. i really love the way they look too.
    So I got that going for me.....which is nice!
  9. J.C.Staley
    J.C.Staley Registered Member
    Sep 23, 2000
    71
    Utah
    Re: 33\" Tires
    My 33s had no problem on a stock 84. They were 9.5 wide and that's the difference. Any wider you need to lift. I did put a 2" add-a-leaf so I could fit chains on the front as well as the rear but if you never need chains you can run 33x9.50 on a stock K5
  10. FatBoyBlazer
    FatBoyBlazer 1/2 ton status
    Feb 22, 2001
    1,508
    Worcester, MA
    Re: 33\" Tires
    i have 32x11.5 they only rubbed when i ramped it(loading dock) and then i put on the lift and i flexed it on a ramp(loading dock thing) an i came close to rubbing them in the back
    hola
  11. chev4life
    Jun 21, 2001
    416
    San Jose, CA
    Re: 33\" Tires
    What parts do you have to trim? Is it a pretty simple trim job?
  12. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Re: 33\" Tires
    Check out the tech section on this site, there are pictures and a write up.
    <a target="_blank" href=http://new.wavlist.com/movies/031/ag-blow.wav>"I ain't nobody, dork."</a>
    <a target="_blank" href=http://www.geocities.com/bigkern76>http://www.geocities.com/bigkern76</a>
