33" tires
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by archer, Jan 12, 2001.
  1. archer
    archer 1/2 ton status
    Aug 17, 2000
    136
    tn
    33\" tires
    I haven't lifted my 85 yet, but my 31's are toast. I don't want to buy new 31's just to turn around and replace them. Will 33's fit under a stock height blazer, or do I just need to try and sell them when I can lift it and go to 33's? It looks like they'll fit in back, but the front is iffy. All replies greatly appreciated.
    "who dares wins"
  2. yeild2me
    yeild2me 1/2 ton status
    Jan 7, 2001
    1,309
    fayetteville, nc
    Re: 33" tires
    33's will fit with a 2" add a leaves in the front and 2" blocks in the back. its pretty cheap,too. under a hundred bucks new. in fact i used to run 33 x 14.50 mickeys on 15 x 10 rims and the back never hit, only the front when the wheel was turned and articulated (like backing out of the driveway). i even had the stock shocks on for a few weeks til the ole ranchos came in.
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Re: 33\" tires
    I ran a set of BFG AT's 33x12.50x15 on the factory rims with no lift. Did lots of wheeling but never rubbed a tire.
  4. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Re: 33\" tires
    The best answer is probably "It depends" It depends on how much your stock springs have sagged, andhow big the tire actually is. If you only use it for the street for a while, It should be fine.
    90K5
  5. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    Re: 33\" tires
    33's "should" fit if you use stock rims. aftermarket rims have a different offset and space the rim out farther.
    your right. I don't understand the jeep thing!
  6. dewey
    dewey Registered Member
    Dec 17, 2000
    59
    MA
    Re: 33\" tires
    One other way to go is 32"x11.5 tires..
    D.
  7. K5Jimmy
    K5Jimmy 1/2 ton status
    Sep 21, 2000
    1,141
    Lake Dardanelle/Logan Co, Ark
    Re: 33\" tires
    I believe that 33's on stock rims will hit the left front wheelwell in the back when the wheels are turned full left...if you drive it turned full left , up over a curb for example, it will more than likely hit...the reason being....in order to make a vehicle run straight down a crowned road (all paved roads are crowned), the wheels are not exactly opposite...the left front wheel sits back just a fraction more than the right.....IF it's gonna hit, this is the most likely place it will hit first...compressing the suspension with the wheels turned will exaggerate this condition...you may trial fit on the front, turn the wheel, and jack it up to compress your suspension...my guess is that it will hit under these conditions....I have run 32's on stock suspension with no probs....running a wider rim changes the arc of the path and can sometimes make clearance better (or worse)....on your truck you must have no more than 3 5/8" back spacing on the rims, otherwise you will hit the tierod ends...(4" spacing will not work)....this means that if you change your rims to 10", you add all your width outboard (from stock 8"), and increase the probability of rubbing with a stock suspension.......there have been a couple articles on this over the past year or so in a couple of the 4x4 mags....I'd go with the 32's and change the suspension when you can.....or.....try to find a set of used 31's for cheap, and do the susp/tire/wheel upgrades when the beans roll in.....I hate having to make decisions like this myself....good luck.....JD
    89 Jimmy headers built 700R Auburns Molys 4:10 4" 10B/12B Con-ferrs 10" Rallies 33" BFG Muds Alpine/Fosgate
  8. JimmyDie6.2
    JimmyDie6.2 1/2 ton status
    Jun 20, 2000
    453
    Long Island
    Re: 33\" tires
    I put 33s on my 83, after switching out the diesel the truck went up about 3/4 of an inch from less weight. I did however have to cut (trim) the fenders at the bottoms, I used a cut off wheel, It isn't noticeable at all. I would If you don't want to cut, take the above advice and lift your truck up first, before 33s....................js
  9. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    Re: 33\" tires
    i have a 77 with no lift and 33x12.5x16in and i can articulate very well and i still do not rub and no fender trimming
    s.smith 77blazer lookin 4 mud
  10. K5Jimmy
    Sep 21, 2000
    1,141
    Re: 33\" tires
    I can run 33's on stock rims and no lift on my 79....rubs with 10" Aluminum Slots......if your 16's are narrower than 8", I'd think that would make a difference.....my 79 started rubbing on stock rims after the springs were about 10 yrs old.....
    89 Jimmy headers built 700R Auburns Molys 4:10 4" 10B/12B Con-ferrs 10" Rallies 33" BFG Muds Alpine/Fosgate<P ID="edit"><FONT SIZE=-1>Edited by K5Jimmy on 01/13/01 08:17 AM (server time).</FONT></P>
  11. Hayduke
    Hayduke 1/2 ton status
    May 9, 2000
    271
    NE Columbus, Ohio
    Re: 33\" tires
    i've got 32" X 11.5" tires on my stock height jimmy and they have only rubbed when wheeling hard, i bet 33" would fit fine for street use...
    peace.
    HAYDUKE
    Insured By COLT, Policy #.357M
    <A target="_blank" HREF=http://haydukesk5.coloradok5.com>http://haydukesk5.coloradok5.com</A>
