33 to steel rims not lifted
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 79tx4x4, Jan 23, 2001.
  1. 79tx4x4
    79tx4x4 Registered Member
    Dec 9, 2000
    17
    houston
    I am wondering if I can put 33x12.5x15 to the stock steel rims on my 84'4x4 without lifting on four corners. thanks!
  2. Stoopalini
    Stoopalini 1/2 ton status
    Oct 17, 2000
    999
    Austin, Texas
    The best answer to giv you is Maybe.
    Some stock K5's can take them, and others can't. It really depends on the truck. The best thing to do is go to a dealer and have them fit the tires on and see what its like.
    I had an '88 Full Size Jimmy that did fit 33x12.5x15's with a stock suspension; but they rubbed when I went 4 wheeling.
    If they do fit, chances are they will rub.
    Thomas.
    -- '84 K5 Blazer --
    <A target="_blank" HREF=http://Stoopalini.coloradok5.com>http://Stoopalini.coloradok5.com</A>
  3. Grim-Reaper
    7,385
    Atlanta
    Depends on the truck and the brand tire. On my 79 BFG M/T's 33's would not fit. They hit the bottom edge of the fender. Trim about an inch out of the fender at the very bottom and they will fit. I ended up running 32's. They fit without mods but under full stuff they would scrub and still do scrub after a 4 inch lift.
    Diging it in the dirt with my K5's
    Grim-Reaper
    <A target="_blank" HREF=http://grimsk5s.coloradok5.com/>http://grimsk5s.coloradok5.com/</A>
  4. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    This is what I've got on my 71 Blazer.33"X12.5"X15" on stock 80's steel rims,no lift,no rubbing.
    [​IMG]<font color=green>BobK<font color=green>
  5. Cavalry
    Cavalry 1/2 ton status
    Oct 1, 2000
    978
    upstate NY(although I cant figure out why)
    Do a search on it.... I asked the same question a few months ago. A few guys posted pictures of their rigs.
    Luke
    84 K5
  6. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Usually they rub when you are turning and going up a driveway or off-road. You may want to try the new(?) BFG 33x10.5 size. Those should fit nicely. Also a good tire shp will usually test fit the tires to see if they rub.
    90K5
  7. J.C.Staley
    J.C.Staley Registered Member
    Sep 23, 2000
    71
    Utah
    On my 84 K5 I ran 33x9.50x15 for over 1 year with out lifting but went ahead and last month put in a 2" add-a-leaf lift because I could not put chains on the front or mud flaps with out tearing them off. I'm am reasonably certain if you put the 33x12.50x15s on you will soon regret it. The tires I used were Kelly Springfield Safari's and had I not wanted be be able to chain up or put on mud flaps to protect the paint I would never have bothered with the lift. If I could ever figure out how to attach a picture I'd let you see both before and after the lift.
  8. Cavalry
    Oct 1, 2000
    978
    If you have the pics online somewhere give me teh url and i'll put them up....or mail them to me and i'll put them up
    Luke
    84 K5
