33's on 3.08's should be fine right?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by anatomiczero, Nov 4, 2002.
  1. anatomiczero
    anatomiczero 1/2 ton status
    Jun 26, 2001
    418
    Washington
    33\'s on 3.08\'s should be fine right?
    Well I'm selling my computer to a friend for $1,200 (will use parent's for a while) and I'll have some money saved. Right now I have 32 x 10 or 11.5's. So going to 33x 12.5's shouldn't be a big difference right? I also want to lift it 2.5" because the front springs bottom out going over speed bumps a little fast /forums/images/graemlins/shocked.gif
    Oh, and is it going to be close to 1 grand for 3.73 gears installed?
  2. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    Re: 33\'s on 3.08\'s should be fine right?
    I'm no expert but I just made the same decisions.
    3.08 and big tires = low rpm at 65mph = no power
    Instead of putting in new gears, I rounded up some used 3.73's - rotor to rotor - drum to drum. $100 for the set and a weekends worth of work.
    My 3.08's did run and drive fine though (35's.) However, I did not wheel or tow with them. I also spent alot of time in 2nd gear just getting around town...
  3. anatomiczero
    Jun 26, 2001
    418
    Washington
    I'll eventually get 3.73 or 4.11 gears, just making sure it wont' be too bad until I can afford them because my tires don't have a lot of tread left and the springs bottom out.
    Oh and should I stick with BFG A/T or get their mud ones? It's my daily driver and I live in WA (rain & snow) don't do a whole lot of off-roading (for now anyway). Would the mud tires wear a lot faster than the A/T and be a lot louder?
  4. 85 blazer
    85 blazer 1/2 ton status
    Feb 12, 2002
    118
    Avoca NY
    If your going to keep your 33s then 373 will be ok I had 33s with 411 and at 65 was running 3100 rpm so jumped to 36 TSLs
  5. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I ran the 35" AT's nd they lasted for years. And I mean years of lots of driving. They saw the Oregon coast, California, and Vegas twice. Sold them when I went to 1 ton setup. If you see light duty mud, I think the AT is a good tire. I hear that the MT weares well also but have never had that tire.
  6. Troopie's Tonka
    Troopie's Tonka 1/2 ton status
    Oct 3, 2002
    284
    Aiken, SC
    /forums/images/graemlins/deal.gif before you drop a grand for new gears, I would look around on this site or in the paper for a little while. People usually upgrade to better stuff and sell their old stuff pretty cheap. I had stock axles and gears (P.O.S. 2.73's, that I am trying to get rid of to the lowest bidder /forums/images/graemlins/rotfl.gif ) and was going to get some 4.11's installed. I was quoted anywhere from 1K-2K around town. I was lucky enough to find a guy on here, Thanks Depdog, that was selling better axles with 4.56 gears and lockers for a grand. My patience paid off. Just be patient and your /forums/images/graemlins/k5.gif will end up just the way you want it... until you decide to upgrade again...ugh..never can stop upgrading can we?
  7. georgiared84
    georgiared84 1/2 ton status
    Sep 5, 2002
    487
    Austell, Georgia
    I've got 33's with 3.08 and a 700r4. Been running them for about a year, and they were run for a while before I got it.. I've got a 14 bolt with 410's that's going on the truck next spring. (just don't have time right now.) You've got to cruise in overdrive at about 70 to keep it from shifting back and forth constantly. I don't run mine on the highway much, so I usually keep it out of overdrive. It's also very hilly here. I just changed the trans. fluid yesterday, and it was still pretty red. No burnt smell or metal. Filter looked clean too. Of course, I run a trans cooler that takes up almost half of the grill. I'm not very forgiving on my trans. I do a lot of hill climbing, and since I don't get a lot of take off power with the 3.08's I usually stomp it just to hear the engine. Even with all that the trans has lasted for 35000 with no probs. (I assume it's the trans you're concerned about since the bigger tires and 3.08's come close to it's torque limit. especially when you drive like I do) It all depends on your trans. If you have a th350, or 400, you will have pretty slow takeoffs. The 700R4 has a nice low first gear that helps make up for it.
  8. RockaFella
    RockaFella Registered Member
    Sep 12, 2002
    63
    South Carolina, Rockhill
    Yes it will be ok I am running 33's on a 3.08 and my Blazer is Fine Pulls Like a Mule Seriously I think i am gonna take my 4.11 out of my 81 GMC
  9. Grim-Reaper
    7,385
    Atlanta
    You can get away with it for a while with the TH350 your truck has. It will just be a dog is all. Put a big tranny cooler on to help keep from frying the transmission. 3.73's and 33's is a good combinations for the TH350. Will let you run down the hwy without screaming the engine to bad.
    If you had a 700R4 I would say that your pushing it. 33's with a 700R4 should run a 4.10 gear.
  10. RockaFella
    Sep 12, 2002
    63
    anatomiczero why are u still a pavement pounder? u have 246 Post or summin like that... /forums/images/graemlins/deal.gif
  11. anatomiczero
    Jun 26, 2001
    418
    Washington
    [/ QUOTE ] Good question /forums/images/graemlins/pimp1.gif Thanks everyone, I'll be patient for the gears.
