33's or 35's on 4" lift
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by bp71k5, Sep 14, 2006.
  1. bp71k5
    bp71k5 3/4 ton status Premium Member
    Mar 31, 2006
    6,235
    284
    San Jose, California
    I think I've read all the articles there are on this subject, but it seems like some say you can run 35's with 4-6" of lift without any trimming, but some say they still have some rubbing. Can anyone with a 1st-gen confirm 35's won't rub with a 4" lift (4" in front, 6" in rear). I'd rather go 35's but am afraid they'll rub.
  2. Roland_Jenkins
    Roland_Jenkins Registered Member
    Apr 14, 2006
    58
    Newport Washington
    I had a 72 with 4" spring lift and 2" body lift no trimming. The rear's didn't just rub they bent in the panel behind the rear wheel. I was on Prichett Canyon trail in Moab. Tires were 12.50x35x16.5 BF AT's
  3. bp71k5
    Mar 31, 2006
    6,235
    284
    Ah, good to know. That's what I was afraid of. 33's looks like the better option.
  4. Jimmy4matt
    Jimmy4matt Registered Member
    Feb 7, 2005
    74
    Campbell, California
    I guess you alread have your answer, but for what it's worth I have a 4" skyjacker lift and 35" bfg at on 15x10 and they rub hard in front on decent bumps with wheel slightly turned. I need to trim lower front of front fenders.
  5. bigblock72
    bigblock72 1/2 ton status Premium Member GMOTM Winner
    Oct 18, 2005
    1,234
    58
    American Fork, Utah
    35s can work without trimming on 8 inch wheels. My dad's 72 K5 has 4 inch springs, 35 inch Baja Claws on M.T. Classic IIs and only very minor rubbing. There is no way to not rub with 10 inch wheels no matter what lift you use, unless you limit up travel with long bumpstops. If you want to go with 10 inch wheels then you need to move the front axle forward an inch and trim the front of the wheel opening, then use bumptops to keep the tire out of the inner fender.
  6. packer
    packer Registered Member
    Sep 23, 2005
    8
    midlothian ,va.
    My 72 has 4 inch lift, springs in front blocks in back with 35" bfg on 8" stock factory rally wheels and never had any problems.
  7. vtblazer
    vtblazer 1/2 ton status GMOTM Winner
    Sep 30, 2003
    2,471
    Central VT
    All depends on how your going to use it.
    (general rule of thumb) cause there are always exception's.
    33's are the max. if your only running a 4" lift and your going to wheel it hard.
    35's with a 4" lift work pavement pounding/mall cruising and dirt roads.
    Wheel width and back spacing play a big part in the equation as well.
  8. CDA 455
    CDA 455 3/4 ton status
    Jun 2, 2006
    8,598
    43rd State
    I haven't read every comment on this thread so I apologize if I'm redundant.
    On the front springs use O.R.D.'s Zero Rate Springs to move your axle forward so it doesn't rub the rear part of the front fender.
    Points to remember:
    1)All the stock wheel well openings are approximately 36" at the base.
    2)Depending on the tire brand, '35's' are really 33.5" to 34" BRAND NEW:haha: .
    3)The metric tire sizes are much more accurate on their sizes.
    4)When you measure tires for their ACTUAL size, make sure they're mounted
    on a rim and aired up to street p.s.i.
    5)IDEALLY, a suspension lift is ONLY for MORE articulation. Take a look at a Baja 1000 Trophy Truck; they SIT at about the same height as a stock '72 4X4 Blazer but have almost 34" of wheel travel!!
  9. bp71k5
    Mar 31, 2006
    6,235
    284
    Thanksfor all the comments. It looks like I'll plan for 33's since my axle locations aren't centered all that well anymore after the lift. I may have to try to move the rear axle back some at least.
  10. Greg72
    Mar 5, 2001
    15,680
    1,391
    642 Days to BB2018
    It is probably worth noting that with a leafsprung/rear shackle'd suspension.....as the wheel travels UP it also travels BACK in the wheelwell.
    This may not be enough to prevent rubbing, if your axle offset is severe but it also might not be as bad as you think. :thinking:
  11. bp71k5
    Mar 31, 2006
    6,235
    284
    That's a good point. It does look similar to some other pictures I've seen, but I won't know till I can actually drive it. Hopefully by this weekend it will drive out of the garage on it's own 4 wheels.
