33's or 35's????
Discussion in 'The Garage' started by Tshane, Jan 28, 2003.
  1. Tshane
    Tshane 1/2 ton status
    Nov 26, 2002
    144
    Peoria, Illinois
    33\'s or 35\'s????
    Okay guys i'm putting a 14bff in no doubt i'm not wasting the money to put gears and locker into a 10 bolt. now should i run 33's or 35's. i'm starting to think 35's cuz i'm loosing so much ground clearance with the 14 bolt to go 35's. And if i do go with 35's would u run 4:10's or 4:56's
    /forums/images/graemlins/truck.gif
  2. schmuck
    schmuck 1/2 ton status
    Nov 11, 2002
    523
    nola(new orleans LA)
    Re: 33\'s or 35\'s????
    still running 3.08s not had a problem but dont climb rocks
  3. K5Dan
    K5Dan 1/2 ton status
    Nov 15, 2002
    583
    Port St. Lucie,Fl
    are 35's what you want or did you want to go bigger?
  4. Tshane
    Nov 26, 2002
    144
    Peoria, Illinois
    no i dont want to go bigger then 35's
  5. K5Dan
    Nov 15, 2002
    583
    Port St. Lucie,Fl
    then 35's it is. i ran 36's with my stock 3.42 wasnt to bad .i'd say 4.10 would be good.
  6. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    You would be fine with the 4.10's and 35"'s. I ran 35"s with 3.73 for years.
  7. blwnbwtie
    blwnbwtie Registered Member
    Jun 4, 2002
    72
    LA California
    i would go with the 35s im running 3.73s on 35s and its been fine for me. eventually i want to go with 4.10s or 4.56s
  8. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    The price difference between 33s and 35s is neglible (for most MT tires.) Go 35s. You'll never be driving your truck on 35s and think "gee, I sure wish I had smaller tires." If you go with the 33s, you will eventually kick yourself.
    -- Mike
  9. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    For the longest time I was planing on 35" tires. Well, now it's going to be 37" tires.
  10. Mreetz
    Mreetz 1/2 ton status
    Jun 26, 2001
    1,282
    Subs of Denver, Colorado
    I've got 35s and just went from 3:73s to 4:11s and am really likin that a lot!!
  11. MilpitasK5
    MilpitasK5 1/2 ton status
    Nov 13, 2001
    889
    Milpitas, Ca.
  12. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    id go with 4.10 gearing with the 35's.this is going to be my setup and it has been my experience so far that alot of 14 bolts come with the 4.10 gearing from the factory.at every junkyard i went to i found most all are 4.10 and i have only found one that wasn't.it was 3.73.
