  1. Roostr84
    Roostr84 1/2 ton status
    Aug 19, 2000
    451
    NJ
    33\'s
    How much rubbing do you think I'll encounter mounting 33x 12.5's on a stock size lift with bushwacker cutout fender flares?
    Chris =)
    www.roostr84.coloradok5.com
  2. flblazer
    flblazer 1/2 ton status
    Nov 24, 2000
    149
    tampa fl
    Re: 33\'s
    just the frnt will rub when you turn or hit a big bunp i have 35s an a 4" no rub check my webpage www.flblazer.alloffroad.com
    can some 1 find me a ford i need to take a pee still peein on that ford just have to keep goin dam i can not stop pissin:) k5s kings
  3. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    Re: 33\'s
    I actually did not get any rubbing in the front. i got the rubbing on the inner fender wells at a mild offroad angle. I put in a 2" body lift and leveled off the rear with a 2" block, i get no more rubbing.
    i guess it depends how twisted you get off road.
    later,
    ARQ.
    PS: this is with stock lift.
    1-72 4x4 CST Blazer
    2-71 4x4 CST Blazer
  4. blazerman
    blazerman Registered Member
    Apr 12, 2001
    44
    Sacramento, CA
    Re: 33\'s
    All I've ever got was a little bit at the rear of the front fender when the wheel was turned. But nothing that ever did any serious damage.
    72 K5 - 33's on stock susp. and lots of rust! But at least it's payed for!!!
