33x12.50 on a 7" rim?
Discussion in 'The Garage' started by 91GMCSuburban, Feb 24, 2005.
  1. 91GMCSuburban
    91GMCSuburban 1/2 ton status
    Dec 9, 2002
    318
    San Antonio, TX
    Any body run 33x12.50x15 on a 7" rim?
  2. firefighter184
    firefighter184 1/2 ton status
    Apr 5, 2003
    2,763
    The Barrio
    Did it for a year, no probs at all. Only reason I stopped is I wanted to change the backspacing. Might rub a bit if you aren't lifted enough, or you might need a TINY bit of trimming...:hack:
  3. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    im running 39.5x13.5x16's on a 16x6.75in rim i have had no problems at all:D
  4. MITCH_89'
    MITCH_89' Registered Member
    Dec 7, 2000
    91
    GULF BREEZE, FL.
    I have a friend that runs that setup and he hates it. He claims that with the buldge of the tire, he gets body roll, especially when towing. Just a thought.
  5. goldwing2000
    goldwing2000 Guest
    Running a wide tire on a narrow wheel will technically work (it will hold air and roll) but it will wear out the center of the tread faster and possibly cause the aforementioned body roll because of the ballooning.
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    7" wheel and 12.50 tire will be fine.
    I run a 16" wide tire on a 10" wheel.
