33x12.50 on Ten inch rim
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 88bblazen, Dec 19, 2005.
  1. 88bblazen
    88bblazen Registered Member
    Mar 23, 2004
    32
    SouthTexas
    Is anyone running stock suspension with 33x12.50 with 15x10 rims just got some question if you do thanx.:bow:
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I WAS running that size tires on 15x8's, now I'm 6" lift with the same tires.
  3. JIMs70K25
    JIMs70K25 1/2 ton status
    Dec 31, 2001
    524
    Chesapeake, VA
    I'm running 33-12.5s on 16.5" x 8.25" rims. I can get the tires to rub while flexed and turning.
  4. blackblazer717
    blackblazer717 1/2 ton status
    Jul 1, 2004
    470
    massachusetts
    back when my truck was pritty much stock
    i had 33x12.50x15's on a 15x10 with stock suspension and no fender mods. it would rub the rear corner of the front fender under moderate flex but otherwise was ok
    LUKE
  5. Jeff Carr
    Jeff Carr Registered Member
    Dec 22, 2005
    48
    Pa
    What was the backspacing of your rims?
