33x12.50x15 8" wheel???
Discussion in 'The Garage' started by dustyk5, Apr 5, 2004.
  1. dustyk5
    dustyk5 Registered Member
    Apr 4, 2004
    12
    33x12.50x15 8\" wheel???
    is a 12.50 tire safe to run on an 8" wheel?My rig is a daily driver that sees limited offroad use,maybe a few times a month tops.the tires are bfg all-terrains and the wheels are factory rally wheels.Thanks,and sorry about that roll bar post.
  2. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Re: 33x12.50x15 8\" wheel???
    Yes. Done it for the past 7 years without a problem.
  3. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    Yes it will be fine, most guys here run 8" width with 12.5's they say the bead angle is better on an 8" rim also, that's what I hear /forums/images/graemlins/thumb.gif
  4. Sidepipes
    Sidepipes 1/2 ton status
    Nov 9, 2002
    139
    St. Thomas, Ontario, Canada
    I'm running them on the stock 7" alum. no problem but I have to run 30PSI to get even wear on them
  5. dyeager535
    26,977
    If you haven't purchased them yet, there are also 33x10.5R15 BFG's in AT and MT.
    Not that you can't run a 12.5 on an 8" rim, just that there are options out there. Tires rubbing the fenders if not lifted is the only real concern.
  6. scoutillac
    scoutillac 1/2 ton status
    Feb 24, 2004
    423
    Spokane, Wa.
    I run a 35-12.5 on an 8". On the snow and sand I go as low as 7 psi. Never busted a bead[knock on wood]
  7. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    It will fit perfect, and those BFG's you want have a bigger lip around tire so you can't easily smack the rim with a rock /forums/images/graemlins/thumb.gif
