33x12.50x15 on stock 15x8?
Discussion in 'The Garage' started by bryguy00b, Jul 11, 2003.
  1. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    will it work?
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    yes /forums/images/graemlins/thumb.gif
  3. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    cool..would there be to much buldge or anything in the sidewalls..im thinking about ordering a set of dunlop mud rovers from tire rack..33x12.50x15...88 bucks a pop...406 shipped ot my door for 4! /forums/images/graemlins/thumb.gif
  4. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    nope
  5. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    I ran that combo for years...15x8 rallys. /forums/images/graemlins/cool.gif
    It worked for me.. /forums/images/graemlins/thumb.gif
  6. LlanoK5
    LlanoK5 1/2 ton status
    May 26, 2002
    202
    Llano, Tx
    Well lets see, I've had my /forums/images/graemlins/k5.gif for 1 1/2 yrs with that combo. The previous owner said that he had it for 2 yrs with the same tires. So I'm guessing that it works, I haven't had any problems with it.
    Kirk
  7. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    cool thanx guys i guess ill go with it then!
  8. dyeager535
    26,982
    191
    Not to start his again, I assume you know that the 33x12.5 will most likely rub with no lift or trimming, right?
  9. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    yea im aware of it...im hoping not though since my truck sits more like a 3/4 with the add-a-leafes but i am expecting it yes.. /forums/images/graemlins/smirk.gif
  10. LlanoK5
    May 26, 2002
    202
    Llano, Tx
    I don't have a lift and mine don't rub. Does have someting to do with dual shocks? I don't if it does or not but I don't rub even flexing.
    Kirk
  11. dyeager535
    26,982
    191
    There are enough variables that some people MIGHT not rub. '73-80 had different front wheel well openings than '81-91. Two vs. three leaf springs. 2 vs. 4wd. Stock rim vs. aftermarket. Advertised vs. actual tire size. Amount the steering linkage allows the wheels to turn.
    AFAIK there was no prerequisite for quad shocks, you could have ordered them with a 2 or 3 leaf front setup, so I doubt that comes into play.
    But with that many variables, with the right combination, certainly some people will be able to run them with no problem, while most DO have rubbing issues.
    Tire width seems to be the main problem, given a stock wheel/height and comparing the 10.5 and 12.5" wide 33" tall tires.
  12. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    NNNNNOOOOOOOOOO!!!!!!!
    YOU CANNOT RUN 33'S ON FREAKING STOCK SUSPENSION. IT IS NOT POSSIBLE!!!!!!!
    But you can run 35's though /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  13. ducttape114
    ducttape114 1/2 ton status
    Aug 1, 2002
    990
    Orcutt Ca
    i ran that set up for about 2 years with minimal rubage. it only rubed when i turned going up a hill, like off a flat street into a sloped driveway. yet it rarly rubed when wheeling. /forums/images/graemlins/confused.gif
  14. LlanoK5
    May 26, 2002
    202
    Llano, Tx
    My /forums/images/graemlins/k5.gif is factory as far as I know, except for the tires. It was this way when I bought it. Quad shock with two leaves, running Genneral Grabber ST 33x12.50x15, no lift or trimming. I do not have any rubbing problems what so ever, so nobody can tell that it can't be done, I do it everyday.
    Kirk
  15. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    I've always found that if someone were to do a search for let's say "33's on stock suspension," the world's premier end all about the subject will come up /forums/images/graemlins/thumb.gif
  16. dyeager535
    26,982
    191
    Actually, I CAN tell you that not everyone will be able to do it, because its true. Bubba Ray's thread about 33" tires is rather lengthy, and if you read it, you'll see that just because YOU can fit them, doesn't mean that they will work for *everyone*, because they won't.
