34" LTB + M1008, Hit or Fit?
Discussion in 'The Garage' started by DukeBoy88, Apr 8, 2005.
  1. DukeBoy88
    DukeBoy88 1/2 ton status
    Oct 16, 2002
    315
    Jonestown Pa
    Does anyone know if a Interco Super Swamper LTB tire with dimensions of 34x10.50-16LT (actual height 33.6 ) mounted on a stock 16x8 rim would fit without clearance problems on a unmodified M1008? My measurements with cardboard seem to say that it will, but if anyone knows for sure it would be greatly appreciated. Thank you
  2. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Should, maybe a little fender trimming:hack:
  3. jkce457
    jkce457 1/2 ton status
    Nov 22, 2002
    135
    Southbury, CT
    I had those tires on a K2500 with stock suspension. They fit with no problem, but I had already trimmed the fenders to fit 35's.
  4. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    I'm running 285/75R16's on 16x8 rims (about 32.8" tall) on my '79 K10 (Also have a 6.2L diesel and stock front springs from a low mileage M1008 in the front). I had to bend back a rear lip slightly to clear on turns when I was on the brake but you wouldn't notice it by looking at the fenders.
    I'd guess you might need a little bit of work to clear the lower parts of the fenders, but not enough to worry about.
