348 and 331 joints
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by R72K5, Apr 27, 2002.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    ok is NAPA 348 U joint the correct U joint to use when converting from 3/4 ton to 1/2 ton in 68 and is the 331 U joint correct for 68 3/4 ton 4 speed ?
    just checking, thats what I got today at NAPA,. says fed Mogul on the box, I suppose this is Spicer nowadays ?
    thanks
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Yes, it is a 348. The 447 is for newer trucks w/ the internal c-clip. The 348 is for external c-clip.
  3. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    NO! Napa Federal Mogul is NOT Spicer. Spicer Ujoints are good. Federal Mogul Ujoints are one step above zip-tying and duck taping the driveshaft to the yoke. I think you have the correct PN for your application, but I strongly suggest a better Ujoint. I prefer Spicer, Autozone's Brute Force, and Carquest....in that order.
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    well that sucks, cannot get spicer parts here, they said they couldnt thne he said they are spicer, i thought fed mog merged, mabye it was with fel pro, hmmmm
    i dunno,,
    cant get any parts in the midwest cornbelt...unless you have a combine.. thanks..
  5. 79Beast
    Dec 9, 2001
    1,155
    Georgia
    You can order anything you need from Randy's Ring and Pinion. I got my D60 steering Ujoints from them...Spicer PN 332X. Basically, if the best is not available, use somethig made in the US with a warranty.
