34x9.5x15 tires
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 88K5Jimmy, Oct 23, 2001.
  1. 88K5Jimmy
    88K5Jimmy 1/2 ton status
    Jan 10, 2001
    1,323
    Tulsa OK
    TSL 34" tires. Just wondering if you guys had any experience with these. I was thinkin a 4" lift and those tires on 8" rally's. I know the are kinda narrow, but just gettin ideas.
  2. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    I really like them on a lighter vehicle, cut down to the bottom real nice. But, on a Blaer I am thinking they may be a little too narrow. I consider the 38.5x11 Boggers sometimes, but I am hesitant for the same reasons.
    Ken H.
    '85 K5 in process
  3. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    I guy in our club has a set of these mounted on 15x8 rims on his '97 TJ (Jeep Wrangler). He had a set of the 33x9.50 BFG muds before he bought the TSL's. While the BFG's looked really skinny, the Swampers look a lot wider in comparison probably because of the huge side lugs. Last time I talked with him he was really happy with the performance on the trail. The Jeep is strictly a trail rig and gets flat towed to the trail most of the time so he doesn't have much experience with them on the road.
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Probably make great snow tires.
    Tim
  5. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    Skinny tires rule the trail. Get em.
    Still Poundin' "pavment" after all these years!!! [​IMG]
  6. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Do you know of any company that makes a 33x10.50 that would fit on a 16.5 rim for my K20?
    <a target="_blank" href=http://www.geocities.com/bigkern76>http://www.geocities.com/bigkern76</a>
  7. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    33x13.50x16, not a 16.5 though.
    <P ID="edit"><FONT class="small">Edited by 90blzr on 10/24/01 05:43 AM.</FONT></P>
  8. 90blzr
    Mar 25, 2001
    3,027
    SO CAL
    Why not go with a 34x10.5x15, 16, or 17 Swamper LTB? Not much wider than a 9.5, but a little. They are new and they are an improved version of the TSL. If you look at one you can tell its a TSL, but there are slight differences. They are bias, just like the TSL too. They are supposed to come out with a radial version of the LTB, but not for some time.
    Swamper has come out with couple new tires, inluding the LTB and the TRxus M/T and the STS All Terrain. They also have a couple new motocross tires out.
    Check out the LTB:
    <a target="_blank" href=http://www.intercotire.com/html/ltb.htm>http://www.intercotire.com/html/ltb.htm</a>
    <P ID="edit"><FONT class="small">Edited by 90blzr on 10/24/01 05:49 AM.</FONT></P>
  9. RedDwarf
    May 9, 2001
    816
    9/32-16.5" Buckshot Mudder. They actually measure a true 33" tall. A little narrower than you wanted @ a nominal 9.4" but they are great tires, good life, great traction in mud. They should fit your stock wheels fine.
  10. dyeager535
    26,982
    191
    Someone mentioned side lugs being prominent, but I looked at 9.5" wide BFG's (for my 8" rims) and since the actual tread isn't 9.5" wide, the bulge in the center looked horrible. if I had attempted to wheel, anything I cleared with tread (like a small pointy rock) would have hit the overhanging sidewall.
    Unless it was a true 9.5" wide at the tread, I would say 10.5" is the narrowest you are going to want to run on 8" wheels.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
    Why insist on counting when the ring gear has the tooth counts stamped in?
  11. 6.2Blazer
    Feb 24, 2000
    4,675
    26
    Ohio
    You are probably talking about my previous post in regards to the side lugs......I was referring to the TSL's and NOT the BFG tires. Yeah, the 33x9.50's looked too narrow to be on the 8" rims, though the 34x9.50 TSL's looked okay.
  12. dyeager535
    26,982
    191
    Yep, exactly..if the side lugs on non-BFG 9.5's are much more prominent, I think I'd be less concerned that the sidewall would be exposed. With the 9.5" BFG's though, if the air in the tire got low, the tread width was so narrow, it appeared the rim could bite into the sidewall.
    Dorian
