35 degree angle from drive shaft to pinion
Discussion in 'The Garage' started by BranndonC, Aug 16, 2005.
  1. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    Im the picture i wrote 30, but its 35, i re-measured.. anyway how do i know how much of a shim i need? Do i need to measure the drive shaft? And if so just to the CV joint or the whole length including the splined end? :confused:
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    You have a CV ? With a CV you point the pinion at the transfercase , down a hair to allow it to move up when giving it throttle . Most of the time a shackle flip does it just right to begin with . Lift springs you will need move it so the pinion is about inline with the shaft in the pic you posted .
  3. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
