$35 power window motors
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by K5Chris, Apr 23, 2004.
  1. K5Chris
    K5Chris 1/2 ton status
    Mar 11, 2002
    805
    New Orleans, LA
    i ordered these motors and just put one side in, and works great. can't beat $35 for brand new lifetime warranty motors. /forums/images/graemlins/waytogo.gif
    http://store.yahoo.com/dpstore/22020900-6.html
  2. hatchetjack
    hatchetjack Registered Member
    Feb 13, 2004
    28
    LA (lower Alabama)
    For sure!! I just replaced one in mine for the second time. Paid more than that for the first one, got the second from NAPA for $39............
  3. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    Just an FYI: It's possible to rebuild the motors. You drill out the 11 rivets that hold the bracket on and motor casing together and pop it apart. Clean the useless hardened grease off the nylon gears with some cleaner. Remove the motor and wipe it down. Turn the motor brushes around to give you 'new' brushes. Apply dielectric grease to all the electrical contacts. Apply new bearing grease to the 3 gears and reassemble the casing. In place of the rivets you drilled out use some 10/24 bolts and nuts with some locktite. It shouldn't take more than an hour or 2 to do and the next time you need to service it, it'll be alot easier. Not only that but it's basically free. Unless there's a gear stripped inside then you should be able to do this.
  4. 88K5Jimmy
    88K5Jimmy 1/2 ton status
    Jan 10, 2001
    1,323
    Tulsa OK
    Do you have to remove the actually window in order to get to the rivets you speak of?
  5. spearchucker
    Nov 17, 2003
    1,556
    Bay area, CA
    You need to remove the motor from the actuator. I don't know remember if you need to take the window regulator out also in order to get the motor off, but I removed the regulator with the motor attached since I wanted to clean and grease it also. The rivets that I drilled out were on the window motor itself. Is that what you were after?
  6. 88K5Jimmy
    Jan 10, 2001
    1,323
    Tulsa OK
    Yeah that helps. I read somewhere that you had to remove the entire window assembly just to dril out the rivets to get the motor off.
  7. spearchucker
    Nov 17, 2003
    1,556
    Bay area, CA
    The motor is held to the regulator with 3 bolts.
