35 splin Warn Hub Problem "Ground the ends,still hits"
Discussion in 'The Garage' started by keith, May 12, 2003.
  1. keith
    keith 1/2 ton status
    1,158
    La Fayette, GA
    35 splin Warn Hub Problem \"Ground the ends,still hits\"
    When I unlock my hubs to the free position it locks into place. When I drive to my destination it has moved to the midway point toward the locked position. It has done this several times. I pulled the hub and the stub shaft is making contact with the hub dial. Warn said I need to cut some off the stub shaft /forums/images/graemlins/angryfire.gifI said bullshit since stores are selling this set up (35 spline kit) I have seen no report or instructions that say you need to modify anything. Whats the deal here Hub Part # 62672, Spicer stub
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    Re: 35 splin Warn Hub Problem
    <font color="green"> Which hubs do you have, the one with the set screw or the one that's meant for the front axles? There is apparantly a mod to fix this problem if you have the set screw axles, it involves pulling the set screw and putting a ball and spring in there so that the hub has a detent at either setting, just like the normal front hubs. </font>
  3. keith
    1,158
    La Fayette, GA
    Warn Hub # 62672 No set screw
  4. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I have heard that if you rotate the hubs side to side that this problem will sometimes cure the problem.
  5. keith
    1,158
    La Fayette, GA
    By doing that it seems you would only be trying the wear the hub dial evenly. I don't get that /forums/images/graemlins/confused.gif
  6. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    From what I have been told is that sometimes the small differences in casting thickness between 2 different hubs can give the axleshaft enough clearence to not rub the dial and turn it. I have heard that it works sometimes, and sometimes not. Worth a shot. Hubs are an easy thing to switch around.
  7. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    I would assume you have the snap ring installed correct? How much does the stub stick past the snap ring/hub face? Lastly, did you install all of the seals on your stub shaft - they might keep the stub pushed in towards the carrier and keep the snap ring tight to the face of the hub. Just some ideas. /forums/images/graemlins/thumb.gif
  8. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Good point, the bronze/plastic thrust bushing on the yoke end of the stub comes to mind in particular, if that was forgotten then the stub could work it's way out when you drive in a straight line for long periods of time. </font>
  9. keith
    1,158
    La Fayette, GA
    It has been sometime since I put it together but I do remember The Bronze thick ring being there. There is another seal in the SBK3 kit that I will check to verify. I hope its there /forums/images/graemlins/rolleyes.gif I was in a hurry to build them. I will check that
  10. Depdog
    Depdog 1/2 ton status Author
    1,657
    Georgia
    Let us know if that works. Tis what I was talking about on the phone mate!
    I got some duct tape you can use to keep the dial from spinning.
    Depdog
  11. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    Cool, Keith loves duct tape
  12. keith
    1,158
    La Fayette, GA
    Duck tape /forums/images/graemlins/rolleyes.gif
  13. keith
    1,158
    La Fayette, GA
    All parts and seals are there /forums/images/graemlins/angryfire.gif
  14. Depdog
    1,657
    Georgia
    Its just a sorry ass GM product, buy a FORD!
    Depdog
  15. keith
    1,158
    La Fayette, GA
    Okay pulled both sides and put the grinder to both axles. All the seals were good and in the right place. After grinding the ends I then put everything back together and when i reach behind the caliper and grab the axle(at the joint) i can pull it in and out and I can still see it make contact with the dial!!!!!!!!! /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gifAny and all ideas are welcome /forums/images/graemlins/1zhelp.gif
  16. keith
    1,158
    La Fayette, GA
    I searched over on pirate and a guy over there had the exact problem. No one ever gave him a cure or a fix
  17. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    Re: 35 splin Warn Hub Problem \"Ground the ends,still hits\"
    Kieth, I had the same problem...and with your front lockright you need to get it fixed ASAP. I talked to Stephen Watson and he said to try swapping the dials side to side. Only the dails, not the hub body. I did it and it worked until the next time I took it apart (to install my gears). Then the problem came back. The constant ratcheting wore the teeth down on my lockright to the point where it wouldn't hold. I cured the problem by installing a dial from a 30 sp set of warn prems (38826 I think). Try it and let me know how it works. Trust me..you are better of running both of them locked than just one.
  18. keith
    1,158
    La Fayette, GA
    Depdog confirmed his warn premiums with the set screw have contact too. This is the or will be the cause of a broken hub on the trail. If you run 35's check to see if your stub hits the hub. You can grab the u-joint and slide it in(toward the diff) then out (toward the hub) you will see the hub dial move if it does hit or hear it.
  19. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Your making me very glad that I got the slugs... Good luck!
  20. keith
    1,158
    La Fayette, GA
    I have slugs too. But this is now a mission /forums/images/graemlins/grin.gif
