35 spline 14b SF?
Discussion in 'The Garage' started by 87k10, Feb 23, 2006.
  1. 87k10
    87k10 Registered Member
    Sep 1, 2005
    31
    colorado
    did they make them?
  2. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I have always been taught that a 14SF is 33 spline and 14FF is 30.
    Ira
  3. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    No, no 35 splines. Like ira said, 33 for sf and 30 for ff
  4. 87k10
    Sep 1, 2005
    31
    colorado
    thanks guys
  5. 82K5_6.5L
    82K5_6.5L 1/2 ton status
    Dec 4, 2002
    439
    Tucson, Az
    y would a semi floater axle have more splines then a full floater? u would think it would be the other way around right?? crazy ass GM :crazy:
  6. sandawgk5
    Oct 28, 2003
    6,881
    The 14FF was designed in the late 60s and was in vehicles starting in 73.
    The 14SF did not show up until I think 78-79? I would assume that they increased spline count to minimize the strength difference between the 2.:dunno: .
    Ira
  7. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    spline count isn't as HUGE an issue as people make of it. When going from one spline countt o a larger one(say as with 30 to 35 spline stub upgrade on Dana 60) the shafts are often larger. That is the bigger strength gain. Splines help of course. A 16 spline D60 shaft won't be as strong as a 40 spline of course.
  8. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    If you NEED to have 35-spline in an SF axle, there's always the Ford D60SF.
  9. dyeager535
    26,982
    191
    Moser doesn't say the axle diameter changed, but the torque numbers based on spline count are actually quite different.
    http://www.moserengineering.com/moser_interior/axletech.htm
    Less splines (t-case input for instance) typically result in very deep cuts, (10 spline) which reduces the shaft size quite a bit. More splines (32 spline) result in far less cutting into the shaft itself, plus more engagement of the actual splines.
  10. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Bingo. More splines, more faces to spread torque onto, hence, more strength.
  11. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Also with the extra load area the cut can be shallower making for a larger minor diameter. That is where the real strenth comes in. A 16 spline shaft can be as strong as a 40 spline if cut the same depth but you would strip the splines. They try to find a happy meduim between snapping shafts and stripping splines.
