35 spline 44 with 60 outers?
Discussion in 'The Garage' started by virgilh, Dec 29, 2006.
  1. virgilh
    virgilh 1/2 ton status
    Sep 8, 2004
    343
    Sacramento California
    has anyone ever seen one of these? just wondering :D
  2. bronc3buster842001
    bronc3buster842001 1/2 ton status
    Sep 30, 2006
    1,996
    6
    leadwood missouri
  3. SUPERSUB87
    SUPERSUB87 1/2 ton status
    Oct 16, 2006
    463
    TEXAS
    i want one!!! thats freakin awesome. wonder how much it would cost to do that. fitting a 35-spline into a d44 housing is insane.
  4. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    i would think u would just break the ring & pinion then, which would be costly to fix. i would rather have the weak link closer to the wheel.
  5. 454k30
    454k30 1/2 ton status GMOTM Winner
    Sep 13, 2004
    1,613
    California, MD
    true to the ring and pinion. This looks like a mod for lighter weight vehilcles like heeps, and tube buggies. Still it is really cool and if you dont run crazy rubber sizes it should stand up forever!
  6. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    x2 and cheaper to fix...
  7. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,996
    134
    Why use a 44 center section when you could use a 9" center section with 60 outers?
    The 69 rules :D
  8. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    the shafts are cool being 2 piece, but I wonder how they hold up. that is still something for small lightweight rigs. would be killer in a samurai with big tires.
  9. virgilh
    Sep 8, 2004
    343
    keep the comments comming its interesting to see what people think. I just finishes building a hp dana 44 with a 35 spline arb deidenbear c's and knuckles 6 lug hubs with 13 inch rotors and willwood 4 piston calipers for a customer. its been my experiance that a dana 44 ring and pinion hasnt failed for streigth reasons all ive ever seen that failed were due to a different failure in the housing. like lack of oil spinning the carrier bering causing a inner pinion bering to fail due to the scrap metal left fron the carrier and bang the ring and pinion fails.
  10. virgilh
    Sep 8, 2004
    343
    i ran full 35 spline dutchman axles in it one piece. from the inner axle to the outer axle all one piece axles it should and will hold up just fine
  11. virgilh
    Sep 8, 2004
    343
    uhhh cause 9 inchers are so superior in looks...:D
  12. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Therobzilla has Superior chromo's in his D44. He has killed several ring & pinions, lockers, & hubs. He finally broke a D44 chromo stub after wheeling on them for a few hard years. Why would you want to pay even more money to upgrade a D44 to 35 spline if you can't really break standard chromo replacements very easy? Then you are just going to start wasting R&P's? Its a waste of time & money to do a 35 spline conversion on a D44 IMHO.
    Harley
