35" tires with a 4" lift fitment
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 91K5, Apr 14, 2002.
  1. 91K5
    91K5 1/2 ton status
    Jul 5, 2000
    185
    Wichita, Kansas
    35\" tires with a 4\" lift fitment
    How well do 35" tires fit with a 4" lift on a K5? I've seen a few on the members rides pages but it looks like it varies a lot for some reason. Some look to fit great while others not so good. I want to fit 35's with as little lift as possible to keep driveline angles down and I'm not too interested in a body lift. Just wondering if this setup works decently.
  2. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    Re: 35\" tires with a 4\" lift fitment
    I had a '79 that 35x12.5x16.5 BFG ATs fit just fine... throw them on, and trim the fenders some... No problem! /forums/images/icons/smile.gif
  3. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    35's on a 15x8" will not rub under normal driving conditions but will rub if off road and put to use. Fitment depends really on what size rim you decide to use, and also what brand lift you have, and how you drive. I personally would not run a 35" tire on a 4" lift without expecting some kind of rubbing going on.
  4. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    I have them on my blazer with a 4" lift they do rub off road but i havent cut the fenders yet but i do have a sway bar in the front and if i really get the front end tweaked while goin over bumpy crap my tires will rub and i have done some body damage from it, but when i trim my fenders i am pretty sure that i will not have that problem anymore, and the back is fine they dont rub at all and i am running 15x10's on 35x12.5 bfg mud terrains, pictures are in the link in my signature
    Hope that helps
    Jason
