35" too big for a 10 bolt?
Discussion in 'The Garage' started by Pookster, Jul 19, 2002.
  1. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    35\" too big for a 10 bolt?
    So I now have an offer on my plate for 35's for a 6lug pattern. Hearing all the bad stuff about 10 bolts snapping and what not.. makes me just a tad bit worried. If I retain the 3.73 gears, will it be mild enough so that I reduce driveline stress? (Or is this not even a factor). I am generally pretty easy on the skinny pedal, and run mostly sand/mud and the occassional mild rock climb.
    Opinions? would also putting a lockright on the front cause excessive stress? The truck fortunately isn't a daily driver, I only use it to tow and carry large items.
  2. backyardbuilt
    backyardbuilt 1/2 ton status
    May 28, 2002
    1,301
    Olathe, Kansas
    Re: 35\" too big for a 10 bolt?
    If you play it right 10 bolts aren't as bad as you might think. my front has held up to 38.5 boggers. It is all about knowing when to let off and when not to. A locker will stress it alot more but it still comes down to the above statement. 35's is the limit 95% of people will tell you for 10 bolts I've seen mud only trucks run 44's with little breakage but the driver has been doing it for 20 years.
  3. kpanza
    kpanza 1/2 ton status
    Dec 8, 2000
    1,579
    Lake Forest, Orange County, California
    Ditto what he said...I had 35s on my 10 bolts for 5+ years with no breakage...now, I will tell you that I am more of a "finesse" driver than a hammer down driver. It's all about driving smartly - if you do that you SHOULD be ok. I emphasize the SHOULD BE part, because you just never know...but if I had to do it all over again from the beginning, I would have no problems using a 10 bolt with 35s. Having said that, once I was able to afford the swap to 14b and D60, I did do it - mainly because my wheeling became more and more on the "harder core" side (that's a relative term to some guys on here!)
    But I would say go for it, you should be ok with them...just always remember that smarter driving is always cheaper!! /forums/images/icons/smile.gif
  4. speed_deed
    speed_deed 1/2 ton status
    Jun 15, 2001
    947
    Valley Center KS
    10 bolts are just fine. Awhile back the FOUR WHEELER magazine had a tahoe with a 10 bolt running 44's. Dont worry about it, just dont drive stupid and 10 bolts will be just fine.
  5. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    Yep, I'm goin' 35-36's, and I ain't skeered! Then again, my anemic 305 couldn't break traction on wet pavement with bald tires.
    John
  6. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Ahh, thanks guys. I have an Eaton Posi on the rear, I hear that that replaces some of the more "breakable" parts on the 10b's. But for the front, I was thinking about a true trac. I guess its one of those balances in life; having a locker means I could get up those obstacles easier, and without having to mash the skinny pedal. Guess I will have to be more careful when trying to turn! (Could always just unlock one wheel.... )
  7. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    In my limited experience, I've only ever seen axles break when the driver was either: wedged in a hole, spinning tires and catching sudden traction, or bouncing the truck with heavy throttle while driving up a big obstacle. Easy does it rules the day and saves the parts.
  8. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    10 bolts aren't that bad... I honestly would be going with my 10b front I bought except I decided to go and build a rock crawler.... and big meats, heavy weight and a 10 bolt is a bad combo, especially since I have a heavy foot... but if you are smart and don't go out to climb the Rubicon with a 10 bolt while gassing it you'll be fine! Crap when I was clueless (pre CK5 days) I did stupid stuff and never busted it... so maybe being clueless is the key to not break stuff! /forums/images/icons/smile.gif
  9. Diesel Dan
    Diesel Dan 1/2 ton status
    Feb 27, 2002
    798
    Warren, Ohio
    We only played in the mud, but as luck had it I never broke my 10 bolt front. Ran fairly bald 36x12.50 TSLs on the front and new 35x16 boggers on the rear with a 14bolt in that truck. All others had D60s.
    Now my brother in-law had new radial TSL 26x12.50s with a milder tread than the bias ply and his D44 broke the carrier in two. I actually think we had more D44 failures in the front than 10 bolts.
  10. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Are you talking about the ol' G.M."Gov-loc"? The factory locker. (it goes by several other names)
    If so, I would take it really easy on the skinny pedal.
    That style of locker requires a tire to slip and spin to activate the locking mechanism and it often engages with a "bang" that can be tuff on parts.
    Like everyone else has said here, taking it easy can help. Allthough, the larger than stock tires will increase the chance of breaking something - no matter how "easy" you are on it.
