350/203 to a 350/208 swap?
Discussion in 'The Garage' started by 77 Mud Buddy, Nov 26, 2002.
  1. 77 Mud Buddy
    77 Mud Buddy 1/2 ton status
    Oct 31, 2002
    228
    Austin, TX
    I currently have a 350/203 set up, I would like to go to a 350/208 set up! I have a 208 with all the levers and linkages lined up! I know I need an adapter plate between the 350 and 208, but what else do I need to make this swap work and how much will that stuff cost? /forums/images/graemlins/1zhelp.gif
    Thanks for the help in advance! /forums/images/graemlins/thumb.gif
  2. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    You will need driveshafts. The front will need to be longer and the rear will need a shaft to fit the slip yoke t-case.
    Dont know if you know it or not, but the 208 shifter mounts to the floor and the 203 mounts to the transfer case adapter.
    You might also want to check on the crossmember, it may be different too.
  3. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I thought that the 203 mounted to the transfer case itself but the 205 mounted to the adapter. I know, splitting hairs.
  4. 4x4Freak
    Apr 21, 2002
    792
    Lubbock, TX
    Well, technically it uses the mounting bolts for the case, but is in front of the adapter. The adapter on a th350/203 is basically a 1/2 inch plate that bolts to the tranny and then the range box.
  5. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    I get it. I've got a 203 adapter sitting on my desk here. I didnt know the linkage used the mounting bolts. thanks.
  6. COCHEV
    COCHEV 1/2 ton status
    Jul 9, 2002
    4,055
    Washougal WA
    i have done this swap and you need to change output shafts to make it work- which means taking your trannie completely apart. you will also need an output shaft out of a th350 that had a 208 behind it. the output shaft is much longer on the 208 versions. not too hard to do though. i had a trannie manual. took a couple hours (once trannie was out) and some assembly grease (holds all the clutches in place. you can use vasaline too i guess) good time to rebuild if you need it. i actually had a 2wd trannie that was is good shape so i used it.
    you'll like being able to stab the 208 on with one arm and start the bolts with the other. can't do that with a 203!
  7. 77 Mud Buddy
    Oct 31, 2002
    228
    Austin, TX
    Thanks for the info! /forums/images/graemlins/thumb.gif I'll have to think about this swap a bit more. /forums/images/graemlins/smirk.gif Any more info /forums/images/graemlins/ears.gif
    Thanks!
  8. COCHEV
    Jul 9, 2002
    4,055
    Washougal WA
    if your trannie is in good shape, go to the junkyard and find a trannie that went to a 208. who cares if its toast, just steal the output shaft out of it for your trannie. get the addaptor too if its still there. i think early 80s are when the where most common. right before they went to the 700r.
