350/208 to 465/205
Discussion in 'The Garage' started by Wally81k5, Feb 20, 2003.
  1. Wally81k5
    Wally81k5 1/2 ton status
    Jul 14, 2002
    139
    Cold Lake Alberta
    I know there hae been some post on this in the past, but i search and can only find a little info. I still have some q's. I have no motor in it right now.
    1)Once i drop the driveshafts and cross member, will the tranny just lower out with the t-case or are there some bolt holding them in on top?
    2)Does anyone have any tips from doing it themselves?
    3)Will my old speedo cable hook up?
    4)What other lines do i need to keep? Like that tv cable or do i not have one?
    5)Whats up with the reverse light going from auto to std?
  2. KrebsATM02
    KrebsATM02 1/2 ton status
    Mar 21, 2000
    553
    College Station, Texas
    Yup, no bolts on the top.
    get a friend, or a jack. Chain it to the frame when you take the bolts out so you don't have to worry about it falling on you, then use the jack to lower it
    don't know
    you shouldn't have one, you probably have a kick down lever and you won't need it
    find where the reverse light is on the auto, i'd imagine it is in the steering column, but i could be wrong.
