350 305
Discussion in 'The Garage' started by foolhardy, Jul 15, 2005.
  1. foolhardy
    foolhardy Registered Member
    Sep 16, 2004
    84
    how can you vissually tell the diffrence from a 305 to a 350 with out looking at the casting numbers. i think my truck has a 350 crate but i am not too shure
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    you can't, they are identicle on the outside. the easiest way is to pull the alternator and find the stamping and look up the suffix.
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    virtually impossible, good luck with that lol especialy in the late 70s and all through the 80s,
    if you know engine is original then you can pretty much figure out which it is by the year make model and application
    any 80s cars would eb 267 or 305
    any 5 or 10 series trucks 80s would be 305
    and it goes from therer
    youre best to get a flashlight and a long flatblade screwdriver or similar instrument and a junk cloth and soem carb cleanr or something along thos elines and clean off that deck stamping pad below behind alternator down there where fuel line form pump to carb is supposed to run(factory)
    get last three CAPITALIZED letters from that deck pad and look for it here: http://www.nastyz28.com/spmenu.html these are listed in
    alphabetical order
    or go to google search home page and type in the three letters and then the term: stamping, or 305, or 350, or engine
    youll find it and have your answer with not much work or time at all, this is how to check any v8 engines and some L-6(later years called I-6) engines
    good luck and happy stamping suffix code decoding
  4. foolhardy
    Sep 16, 2004
    84
    i have have alredy did that there is no stamping i think that the engine is a 87-95
  5. mudslinger99
    mudslinger99 1/2 ton status
    Oct 8, 2004
    512
    East Coast
    Are you sure that is correct ? :whistle:
  6. original balzer
    original balzer 1/2 ton status
    Nov 17, 2004
    4,660
    roosevelt utah
    on the back of the block where the bell houseing bolts ( just below the head and oil pressure hole) on the driverside top is the casting number alot of 85 and newer engines say either 5.0 or 5.7 there. its hard to see but fastest way i know, if its not labeled 5.0 or 5.7 get the number and look it up on mortec.com
    balzer
  7. dyeager535
    26,975
    No, Y bodies,F-bodies and B-bodies for three got 350's. :wink1:
