350, 383 dyno proven recipes
Discussion in 'The Garage' started by Mad-Dog, Apr 12, 2005.
  1. Mad-Dog
    Mad-Dog 1/2 ton status
    Mar 20, 2005
    548
    Ocklawaha,Fl
  2. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,992
    130
    Wow, #19 is almost exactly my engine. Same cam, distributor, pistons, compression ratio, but a 750 CFM modded Quadrajet and vortec heads. I don't think mine quite makes peak power up that high though. Nice post!
  3. tiger9297
    tiger9297 1/2 ton status
    Jul 23, 2004
    1,205
    Tupelo, Mississippi
    Great post. Very helpful as I am in the process of planning a new engine build. :waytogo:
  4. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    i remember seeing this site awhile back. and i was just wondering where i could find it. good timing :waytogo:
  5. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
  6. Mad-Dog
    Mar 20, 2005
    548
    Ocklawaha,Fl
    In response to the thread about "350 vs 383 reliability" and "Dirtwarrior17's comments, no pun intended surpip.....just wanted you to see for yourself how a 350 stacks up against a 383.
  7. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    Ya? So it looks like i was right similar build 383VS. 350. 383 makes more power
  8. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    Some great info! I sure could have used this info last year. It will make it easier on the next one! :)
  9. Mad-Dog
    Mar 20, 2005
    548
    Ocklawaha,Fl
    Yes it does and at a lower rpm, i think the message that DW17 was trying to convey was that 2 similar builds of a 350 and 383 will make similar HP but the 383 will always make more torque because of the 1/4" longer stroke.
  10. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    Eeek, those 5.565 rods on the 383's give me the willys.
  11. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    5.565 is stock 400 I believe.
  12. 1977k5
    May 26, 2003
    9,992
    130
    5.565 rods are stock in a 400, but some people put them in 383's (they get the 400 crank and take the rods with it). This is really too short of a rod and 5.7" rods are so easy to come by that they are usually replaced with them.
  13. BigBurban350
    Jun 9, 2002
    711
    Michigan
    All the better with 6" rods :D
  14. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    Great info! Thanks!
    Combo 5 sounds alot like my engine w/ the huge cam and all.... The P.O. told me the compression is above 9.5:1 but I've yet to verify that.
    -Mike
