350 and 700-r4
Discussion in 'The Garage' started by 1979jimmy350, Mar 29, 2004.
  1. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    I know that the THM 350 and 700-r4 share some of the same parts but I wanted to know would a output shaft from a 350 wourk in a 700-r4
  2. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    NO, they are different.
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    never had them sitting next to each other, but i think they are different
  4. grd2go
    grd2go Registered Member
    Mar 28, 2004
    55
    Anchorage Ak
    no they are different what are you trying to mate the 700-R4 up to?? /forums/images/graemlins/thinking.gif
  5. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    I am trying to mate a 700-R4 to a NP203
  6. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    advanced adapter sells the output shaft for it for like $100.
    if you want to get into some costom machine work, the stock output on the 700r4 is the same spline as the 350, its just longer.
  7. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    Does the 700-r4 shaft have enough spline to cut some off and make it work
  8. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    do you have a 350 4x4 there?
    the 700r4 output is out about 6 in front the tranny case.
  9. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    would there be enough spline left to work with a NP203 if I cut the 700-R4 shaft down to the right size
  10. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    maybe, not sure exacltly what the output of the 350 sticks out
