350 block
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MA87K5, Jul 17, 2001.
  1. MA87K5
    MA87K5 1/2 ton status
    Apr 6, 2000
    558
    Chicopee, Ma 01020
    A friend of mine bought a block for $35. I looked at it and found that it is an 86 or later block. It has a one piece rear main seal. What year did the center bolt valve covers come out and what year did the one piece main seal come out? Would it be a good block to hotrod? Thanks for any info.
  2. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Center bolt valve covers and one piece rear main both started in '86.
    Tim
    70 Blazer CST 4X4 350 SM465 NP205
    87 Burb 4X4 350
    01 GMC 2500HD 4X4 Duramax/Allison
  3. Emmettology 101
    May 9, 2000
    8,126
    FL
    Some of the newer blocks did not have the hole for a mechanical fuel pump. Double check that one if you want to use a mechanical one.
    "I see, said the Blind Man to the Deaf Mute who was walking a dog with no legs!"
    <a target="_blank" href=http://www.geocities.com/emmettology101>www.geocities.com/emmettology101</a>
  4. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    Here is the only thing (that I can think of) to watch for:
    Center-bolt valve covers mean that the intake-to-head-bolt holes in the heads are not all angled at the same rate, like a carb'd intake would be. Let me try to explain...
    The 2 intake-to-head-bolts in the center on each side of the intake are angled more perpendicular to the ground on center-bolt vavle cover engines. Older style blocks will have all 12 bolts at the same angle... most carb'd intakes use the "all same" type bolt pattern!
    Hope I didn't confuse any one other than myself!
    Does anyone else smell BFGs burning???
    454/TH400/NP205 - 14BFF/D60/w/ 4.10s
    <a target="_blank" href=http://24.10.209.54/bigolk5.htm>http://24.10.209.54/bigolk5.htm</a> [​IMG]
  5. Neil
    Neil 1/2 ton status
    Jun 10, 2001
    275
    Dothan,Alabama
    it should say GM LG5.7 on the flywheel housing on top if it is a 86-later 350. the GM LG5.0 is a 305 and so forth. These blocks are OK but older ones are made of heavier duty stuff. They are also cheaper for some parts. If you can get a roller cam and some LT1 rods/pistons that would be cool though. LT1 parts are easy to find...Neil H...Alabama
    Neil H. Alabama '78 K5 400ci 4x4 AT,AC,PW Cheyenne. '74 C10 3spd/floor 250ci 4x2
  6. MA87K5
    Apr 6, 2000
    558
    Chicopee, Ma 01020
    Thank you for the info.
