350 cam upgrade
Discussion in 'Tow & Trailer' started by big pappa b, May 13, 2005.
  1. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    I going to upgrade the cam in the burb before I run out and buy a diesel. I hate car payments. The burb has a 350 vortec motor, hydraulic roller cam. The one that's in it is a L98 flavor. Guess it was a good cam for a car and does well on the flat land but these long hills REALLY slow me down (25-30mph :mad: )
    I've already talked to Comp Cams and have their recommendation. Still need to call Crane and get their opinion.
    Anyone here upgraded their cam? Which one? and do you like it?
  2. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    Anything for low end torque would help with towing. Also, what tires and gears do you have in the burb? They make the biggest difference if you don't have a super torque motor.
  3. big pappa b
    Jan 3, 2003
    6,328
    Falcon, Colorado
    The gears are 4:10 and the tires are 245/75/16 or about 30.5". This seems to be an ideal tire/gear according to the chart on 4Lo.com. The cam and chip change will hopefully help quite a bit
  4. kennyw
    Jun 9, 2002
    13,223
    94
    Sounds like a great tire and gear combo. A good cam for low end torque should help out a lot.
  5. K30CJ
    K30CJ 1/2 ton status
    May 16, 2003
    429
    IN
    FWIW, I had a 350 TBI in a tow rig with 4.10's, no OD and 35's a few years ago. It had a Comp "torque" cam, supposedly the wildest that would cooperate with the computer. It towed quite well for a 350. That engine is now in my jeep. It runs better than your average 350 TBI, and does not show any negative side effects from the cam swap.
