350 carb on a 500? and water in auto tranny question.
Discussion in 'The Garage' started by y5mgisi, Mar 8, 2005.
  1. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    The carb that the 500 came with is in not so great shape. I have a 350 carb that is in pretty good shape. Could i just rejet the 350 carb and slap it on the 500? If so how do i get the jets? Also a buddy of mine tried to flush out his torque converter with a garden hose. He said he did his best to get it all back out but when he put it in his truck and fired it up he got pink tranie fluid out the top of it. He was told that water in the tranie will screw the glue on the friction plates is this true? or is he fine?
  2. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    go to a parts store that has Competent employees.
  3. y5mgisi
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    Have yet to find one:blush:
  4. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    Although the people arent too friendly, The Baxters in hillsboro couple miles from my house, Seems to have 2-3 Competent employees. although one of the Employees used a Micrometer to measure the caps on my u joints, AFTER i told him the part number of the one i needed...
    Napa is usually decent aswell.
  5. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Mitch, call Big A's Auto Parts here in Canby and ask for Dick (503-266-2071) that man knows his sh!t, he is who I deal with all the time :thumb:
  6. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    About the water in the tranny....
    LMFAO holy ****.
    Yes it will screw up the friction plates... Yes he is prolly Screwed.. maybe not right away but definatley took some life outa that Trans...
    I dont see how in the Blue **** somone would think that was ok....
  7. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    yes this is true :(
  8. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    lol
    thats someone who doesnt need to be touching trannies,, or much of anything else automotive either im sure,
    hum
    crazy,
    personally i think an old 350 carb will run a 500 just fine, maybe possibly be a tiny bit lean if is an 80s smogger carb, maybe
    but i doubt it
    the plugs will tell you if its lean or not,
    white if so, and tan, gray, or black if not
    is the only real way to know
    run it and see
    good luck
  9. dyeager535
    26,980
    If the carbs are externally the same, then the primary rods should interchange.
    You get the primary jets (only removable ones) out with a flat blade screwdriver. Take the secondary rods and hangar as well, swap them over, they will fit regardless of year.
    Only problem I ever had with swapping a Q-jet from a smaller engine (not counting lean surge due to missing EGR) to larger was running out of gas when I was really getting on it. Leaning out the secondaries solved that problem.
  10. sweetk30
    Nov 1, 2004
    25,546
    542
    horseheads , ny 14845
    can you say good buy tranny. that thing now needs a rebuild. auto trannys hate h20 big time
  11. towdriver80
    towdriver80 Registered Member
    Jan 16, 2005
    41
    Maybrook, New York
    If the tranny was not run with the water in it, would the damage still be as severe? I had a tranny and tcase get hit by a flash flood. Torque converter was safe in the garage. I pulled them to the garage, and unbolted the pan on the th400. Wouldn`t come off. Tried to persuade it with a 2x4 and lump hammer, when I got it off, there was a block of ice left on the tranny in the exact shape of the pan!:blush: Put it in front of a kerosene heater, and it still leaked tranny fluid and water for a couple days. When it was dry, I set it in a big drain pan and kept pouring fluid in the top until no more water came out the bottom. Is there any chance of this thing being O.K.?
  12. dyeager535
    26,980
    FWIW I had a TH400 that had a leaking dipstick tube. Changed fluid, turned pink after a couple of days. Kept this up for about 3 fluid changes, finally figured out where the water was coming from.
    Fixed the leaking seal, ran it that way for awhile. Was brutally hard on the tranny, so no idea why it really failed, but the clutches were the only failure when I disassembled it.
    Nothing you can do but change the fluid and run it. Even without running it, water was in contact with steel, it probably rusted some things. If it keeps working, great, if it fails, you probably know why. :)
